2000 f250 wiring diagram
karns737
Posted: August 04, 2010 at 7:42 PM / IP Logged
Does anyone have a wiring diagram for a 2000 F250? Also, I can't figure out which wire to use as a remote wire for an aftermarket amplifier. Any help would be greatly appreciated.
karns737
Posted: August 04, 2010 at 7:49 PM / IP Logged
I guess I should specify that I need the radio wiring diagram....
Platinum - Posts: 13,726
Posted: August 04, 2010 at 7:55 PM / IP Logged
 The Accessory wire at the back of the radio will provide 12volts to the remote terminal of the amp anytime the key is on or in the acc position.  They do have line out converters that will also give you a remote output.  If the Acc wire is not an option for you, you may want to look into that.
WIRE COLOR POLARITY LOCATION 2000 f250 wiring diagram -- posted image.
2000 f250 wiring diagram -- posted image. Battery LIGHT GREEN/ PINK (+) RADIO HARNESS
2000 f250 wiring diagram -- posted image. Accesory BLACK/ VIOLET (+) RADIO HARNESS
2000 f250 wiring diagram -- posted image. Ground BLACK (-) RADIO HARNESS
2000 f250 wiring diagram -- posted image. Illumination LIGHT BLUE/RED (+) RADIO HARNESS
2000 f250 wiring diagram -- posted image. Power Antenna AMP=BLUE
2000 f250 wiring diagram -- posted image. LF Speaker (+) LIGHT BLUE/WHITE
2000 f250 wiring diagram -- posted image. LF Speaker (-) ORANGE / LIGHT GREEN
2000 f250 wiring diagram -- posted image. RF Speaker (+) DARK GREEN
2000 f250 wiring diagram -- posted image. RF Speaker (-) WHITE/ LIGHT GREEN
2000 f250 wiring diagram -- posted image. LR Speaker (+) TAN / YELLOW
2000 f250 wiring diagram -- posted image. LR Speaker (-) GRAY/LIGHT BLUE
2000 f250 wiring diagram -- posted image. RR Speaker (+) BROWN / PINK
2000 f250 wiring diagram -- posted image. RR Speaker (-) ORANGE / RED
2000 f250 wiring diagram -- posted image. Amp Location BELOW RADIO
2000 f250 wiring diagram -- posted image. Steering Cntrls NO
karns737
Posted: August 04, 2010 at 9:30 PM / IP Logged
I really appreciate your help. I don't know why i never thought of using the accessory wire. I have always used the remote wires on aftermarket units so i was thinking i needed to use that. Thanks again for the help.
91stt
Silver - Posts: 564
Posted: August 05, 2010 at 3:32 PM / IP Logged
if the blue power antenna wire is present you can use that too
This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
Friday, May 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
