audio wiring diagram for 2001 s500
mikeeg800
Posted: August 11, 2010 at 1:54 AM / IP Logged
can you please provde me with wiring diagram for stereo system for 2001 mercedes S500
thank you
Platinum - Posts: 13,726
Posted: August 11, 2010 at 3:36 AM / IP Logged
What are you trying to do?
Posted: August 11, 2010 at 3:49 AM / IP Logged
This vehicle has fiber-optic input to th eamplifier.  The remote wire for the amp is data controlled.  But here is what Audiovox has for that vehicle.
WIRE COLOR POLARITY LOCATION audio wiring diagram for 2001 s500 -- posted image.
audio wiring diagram for 2001 s500 -- posted image. Battery RED / YELLOW (+) RADIO HARNESS
audio wiring diagram for 2001 s500 -- posted image. Accesory audio wiring diagram for 2001 s500 -- posted image.
audio wiring diagram for 2001 s500 -- posted image. Ground BROWN (-) RADIO HARNESS
audio wiring diagram for 2001 s500 -- posted image. Illumination audio wiring diagram for 2001 s500 -- posted image.
audio wiring diagram for 2001 s500 -- posted image. Amp Turn On ORANGE (DATA) RADIO HARNESS audio wiring diagram for 2001 s500 -- posted image.
audio wiring diagram for 2001 s500 -- posted image. LF Speaker (+) ORANGE audio wiring diagram for 2001 s500 -- posted image.
audio wiring diagram for 2001 s500 -- posted image. LF Speaker (-) ORANGE
audio wiring diagram for 2001 s500 -- posted image. Amp Location ON LEFT SIDE OF TRUNK UNDER FLOOR COVERING
Posted: August 11, 2010 at 12:37 PM / IP Logged
The audio on the S class is basicly don't touch unless it's simply an add on DVD, all inputs are data or fibre optic in the case of the amplifier and changer; DVD inputs need to go through a CAN adapter.
Acc and illumination are picked up at the cigar lighter.
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
