2001 lexus gs430 alarm/rs diagram
KaMLuNg
Copper - Posts: 70
Posted: September 13, 2010 at 2:54 PM / IP Logged
saw a diagram in the database for the 2000 GS4... wasn't sure if any of the color codes changes when they moved to the 430 model in 01.
can someone please confirm or appreciate if you can post the diagram for the 430....
KaMLuNg
Copper - Posts: 70
Posted: September 13, 2010 at 3:06 PM / IP Logged
i think i found it...
 MODEL  YEAR(S)
 GS430  2001 -2003
 KEY  T-HARNESS  IMMOBILIZER
  N/A   N/A   TRANSPONDER, REQUIRES 791 BYPASS and EXTRA IGNITION KEY
 PART   COLOR  LOCATION  DIAGRAM
 12 VOLT CONSTANT   WHITE/ BLUE (+)   IGNITION SWITCH HARNESS
 STARTER  BLACK (+)  IGNITION SWITCH HARNESS
 STARTER 2  N/A
 IGNITION 1  BLACK / YELLOW (+)  IGNITION SWITCH HARNESS
 IGNITION 2  BLACK/ WHITE (+)  IGNITION SWITCH HARNESS
 IGNITION 3  N/A
 ACCESSORY /HEATER BLOWER 1  BLUE / YELLOW (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2  N/A
 KEYSENSE  YELLOW (-)  IGNITION SWITCH HARNESS
 PARKING LIGHTS ( - )  RED / YELLOW (-)  UNDER STEERING COLUMN
 PARKING LIGHTS ( + )  GREEN (+)  @ BOTTOM RIGHT OF FUSE PANEL
 POWER LOCK  See NOTE *1  See DIAGRAM   7376_GS430_TOYOTA and LEXUS door lock interface.pdf
 POWER UNLOCK  See NOTE *1  See DIAGRAM
 LOCK MOTOR WIRE  GREEN/ RED (+)  @ DRIVERS DOOR MODULE in DRIVERS DOOR
 DOOR TRIGGER  See NOTE *2  @ DOOR MODULE IN EACH DOOR   9880_GS430_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf
 DOMELIGHT SUPERVISION  GREEN (-) See NOTE *3  @ PIN 13, IN 25-PIN PLUG, AT BODY ECU, See NOTE *3
 TRUNK RELEASE  BLUE (+)  @ 18-PIN PLUG, IN DRIVERS KICK PANEL
 SLIDING POWER DOOR  N/A
 HORN  GREEN/ BLACK (-)  @ STEERING COLUMN HARNESS
 TACH  BLACK / YELLOW  @ PIN 16, IN 28-PIN PLUG INSIDE ECU BOX See NOTE *4
 WAIT TO START LIGHT  N/A
 BRAKE  GREEN / WHITE (+)  @ 20-PIN PLUG, IN DRIVERS KICK PANEL
 FACTORY ALARM DISARM   Disarms with KEYSENSE Wire  @ IGNITION SWITCH HARNESS
 ANTI-THEFT  TRANSPONDER, REQUIRES 791 BYPASS and EXTRA IGNITION KEY  TRANSPONDER @ IGNITION SWITCH TUMBLER
NOTES
 NOTE *1 THIS VEHICLE'S DOORLOCKS ARE SPECIAL AND WILL REQUIRE AN EXTRA RELAY, PART #775 AND 2 DIODES, TO CONNECT, See DIAGRAM
NOTE *2 THE DRIVERS DOOR TRIGGER IS RED / WHITE(-),THE FRONT PASSENGER DOOR IS RED / GREEN(-),THE LEFT REAR IS RED / WHITE(-),THE RIGHT REAR IS RED / YELLOW(-). WHEN CONNECTING TO AN ALARM SYSTEM, USE ALL 4 DOOR TRIGGER WIRES AND DIODE ISOLATE, TO CONNECT, See DIAGRAM
NOTE *3 THE BODY ECU (ELECTRONIC CONTROL MODULE) IS LOCATED IN THE PASSENGER KICK PANEL.
NOTE *4 THE ECU (ELECTRONIC CONTROL MODULE) IS LOCATED UNDER THE HOOD ON THE DRIVERS SIDE
