Alarm/Remote Start Wiring, 2005 Kia Rio
lottaskull
Posted: November 15, 2010 at 11:23 AM / IP Logged
need wiring diagram for 2005 kia rio to install a remote start system.
also need to know if theren is a bypass required for the key .
not sure of equiptment type not purchased yet.
ExtremeProAudio
Member - Posts: 45
Posted: November 15, 2010 at 12:09 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - KIA / RIO / 2005 / Remote Start
[PRINT THIS PAGE]
12volts      blk/blue (30A), grn/red (30A)      +      ignition harness
Starter      blue      +      ignition harness
Second Starter      N/A
Ignition      blue/red      +      ignition harness
Second Ignition      blue/black      +      ignition harness
Third Ignition      N/A
Accessory      RED / blue      +      ignition harness
Second Accessory      N/A
Keysense      blue      +      ignition harness
Power Lock      red      -      relay high in driver kick
Power Unlock      yellow      -      relay high in driver kick
Lock Motor      blue      5wi      relay high in driver kick
Unlock Motor      green      5wi      relay high in driver kick
Parking Lights+      RED / green (L), blue/black (R)      +      driver kick, harness to rear
Parking Lights-      GREEN/ blue      -      headlight switch or ETWIS
Hazards      same as turn signal wires
Turn Signal(L)      GREEN/ YELLOW      +      turn signal switch
Turn Signal(R)      GREEN / WHITE      +      turn signal switch
Reverse Light      blue/black      +      driver kick, harness to rear
Door Trigger      GREEN/ red      -      ETWIS high in driver kick
Dome Supervision      white      -      ETWIS high in driver kick
Trunk/Hatch Pin      lt. GREEN/ red      -      ETWIS high in driver kick
Hood Pin      lt. GREEN/ YELLOW      -      ETWIS high in driver kick
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      factory remote only
Factory Alarm Disarm      factory remote only
Disarm No Unlock
Tachometer      BROWN / red      ac      ECM or diagnostic plug
Notes: The ECM is in the driver kick panel. The tach wire is in pin 31 in the 52 pin plug.
Can also find the tach wire in the diagnostic plug behind the driver side headlight.
Wait to start      N/A
Brake Wire      RED / black      +      brake pedal switch
Parking Brake      blue/white to blue/black      -      driver kick, harness to rear
Horn Trigger      lt. GREEN/ red      -      horn switch
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
No      Type:
N/A
Part #: N/A
Notes:
warning
Wednesday, July 2, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
