2008 ford explorer eddie bauer
johnmatkinson1
Posted: January 02, 2011 at 12:07 PM / IP Logged
Keypad code location for 08 Exlporer Eddie Bauer?  I have torn truck apart and can't find the SMJ.  Has anyone found the factory keypad code for this truck/
Farmer Fran
johnmatkinson1
Posted: January 02, 2011 at 4:22 PM / IP Logged
Thought I would add what I know for this vehicle; still can't find the factory keycode sticker in the truck anywhere.
12VDC constant:  violet/red ignition harness
12VDC ignition:  WHITE/ orange ignition harness
Starter: blue/white ignition harness
Accessory: violet/green ignition harness
Keysense: Lt blue/grey(+) ignition harness
Brake: viloet/white(+) lower driver kick
Tach wire: Blue/tan or yellow/gray coil pack
Horn: Lt blue/white steering wheel harness
Trunk pin and dome light:  Yellow/gray(+) lower driver kick
lock: gray / YELLOW(-) lower driver kick
unlock: violet/gray(-) lower driver kick
Rear window pop: gray/orange driver side rear
Farmer Fran
