2008 acura tl remote start/directwire 2.0
BChillin83
Copper - Posts: 58
Posted: January 04, 2011 at 7:47 AM / IP Logged
Looking for the wiring diagram for a 2008 Acura TL from DirectWire 2.0. Will be installing a Viper 5901. I believe this car uses the PKH34 immobilizer bypass module, can anyone confirm? I will not be using any xpress kit, just the 5901 and immobilizer. Thanks a ton. Car is a 3.2 base with navigation.
BChillin83
Copper - Posts: 58
Posted: January 04, 2011 at 7:50 AM / IP Logged
Will most likely go by the information on DirectWire 2.0 and also want it to compare other wiring diagrams. If anyone happens to have the PDF file, you would email it to me as well, but would prefer you post it so others on the forum can use it.
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
