ford fiesta 1.6 zetec wiring info
neoskynet
Posted: February 07, 2011 at 12:01 PM / IP Logged
Greetings:
Please help me, i try to install a alarm with starter in a ford fiesta 2003 1.6 made in brasil, i can't find info about these car. ( I searched many times in google but no luck).
I locate only some wires, but my alarm need a RPM wire signal and i can't find them.
Please tell me these info or a link for them.
Aditionally need how to hack the centralized close module for open/close doors with  the alarm.
Posted: February 09, 2011 at 1:58 AM / IP Logged
Lock = BLACK/ orange neg.
Unlock = BLACK/ green neg.
Both at the GEM box.
Use the BLACK/ blue dome light trigger, it also covers the hatch.
RPM, go to injectors 2 wires to each injector, one wire will be the same colour to all injectors, the second will be different for each, use one of the different coloured wires, use a DMM set to 20VAC, red probe to wire, black to ground with engine running, should read 3-6VAC.
I can send you the wiring sheet but it's for the UK version. If you still need it PM me with your email address.
neoskynet
Posted: February 12, 2011 at 9:20 PM / IP Logged
thanks,
for the rpm's i known a cable with the signal that drives the tachometer on the instrument panel. I found a message that said it is the BLACK/ white in harness that connects to the instrument panel, mentioned that there were two but i don't  known how reading with a tester.
please forgive my bad english.
Posted: February 13, 2011 at 4:13 AM / IP Logged
Look at my last post about tach testing, you will need a DMM = Digital Multi Meter.
It can be done with an LED sensor but not at the instrument panel.
Posted: February 13, 2011 at 7:32 AM / IP Logged
I think BLACK/ white is a CAN Hi or Lo, don't touch, instead, look at either BLACK/ green or BLACK/ orange at the coil.
