2011 silverado remote wire
brock1320
Posted: April 19, 2011 at 7:49 PM / IP Logged
I'm trying to find a hookup for my remote wire w/o putting and inline switch and I'm keeping my factory H/U also. I've been searching for awhile but no success and any help will be appreciated.
itsyuk
Silver - Posts: 505
Posted: April 19, 2011 at 10:35 PM / IP Logged
do an ebay search for "radio remote adapter" and see what you think of the one that Directed Audio offers.
yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
Mike M2
Platinum - Posts: 2,652
Posted: April 20, 2011 at 6:32 AM / IP Logged
You could go to the ignition switch and get the brown accessory wire....
Mike M2
Tech Manager
CS Dealer Services
itsyuk
Silver - Posts: 505
Posted: April 20, 2011 at 12:12 PM / IP Logged
using the brown wire is ok but the amp would be on all the time the truck was and your radio might make a big pop through the amp when you turn it on or off.
worth giving a try, but i wouldnt do it because amps dont like those big transients .... but if your amp is not expensive... thats another thing.
keep us posted.
yuk
brock1320
Posted: April 20, 2011 at 4:37 PM / IP Logged
would it just be easier to put an inline switch? If so what would you recommend I tap into, I was thinking the cigarette lighter.
itsyuk
Silver - Posts: 505
Posted: April 20, 2011 at 8:49 PM / IP Logged
no. cos if you left the amp on, it might cause dead battery by morning.
use something that is only powered when the radio is. something that works with the key "on" and on "acc".
is here an "acc" port at the convenience center on the firewall near the drivers kick panel?
yuk
Mike M2
Posted: April 21, 2011 at 4:21 PM / IP Logged
There is nothing in this truck powered just when the radio is. There is nothing in this truck that is even powered just when the key is on other than the brown accessory wire. Use it, works fine...
Mike M2
Tech Manager
CS Dealer Services
brock1320
Posted: April 21, 2011 at 5:33 PM / IP Logged
is the brown accessory wire right by the steering column?
Mike M2
Posted: April 21, 2011 at 6:10 PM / IP Logged
Yes. If you remove the knee bolster under the dash you will see a harness coming down the column from behind the shroud. It's on the left side of the column, traveling down from the ignition switch. There may be more than one brown so test. Also, i have seen some GMC's that use a yellow instead of brown for accessory. The wire is fused 2 amps so it's only good for turn on, nothing else...
Mike M2
Tech Manager
CS Dealer Services
brock1320
Posted: April 21, 2011 at 6:54 PM / IP Logged
what voltage does it read at? I think I only have one that reads at 14v.
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
