nissan stagea wiring
is200_turbo
Copper - Posts: 88
Posted: May 20, 2011 at 7:47 AM / IP Logged
Hi does anyone know where i can obtain a full nissan Stagea Series 1 Wiring layout
This is for,
alarm
door locks
Power windows
Fuse box layout
I have searched but not found anything or anywhere that is as usefull as some off the other cars on here.
cheers
Posted: May 20, 2011 at 11:38 AM / IP Logged
Google
Posted: May 20, 2011 at 11:46 AM / IP Logged
Above facetiousness apart, it should be a piece of cake!
Any competent installer with a DMM should handle it.
You can pick up the wiring as follows:-
Windows, go to motor wires.
Locks, going to be in driver's door loom, either type B NEG pulse or type F NEG and open circuit on 1 yellow/red wire.
Indicators, steering column loom or haz switch, why the fuse box layout?
Main input power will be white.
is200_turbo
Copper - Posts: 88
Posted: May 20, 2011 at 2:05 PM / IP Logged
oh the guy has installed it and everything works except the accessory items as he said they don't install them unless you want to pay extra per O/p which didn't interest me as i haven't decided what i want them to do yet
the wiring diagram was mainly for my records
Posted: May 20, 2011 at 4:47 PM / IP Logged
What accessories?
If you mean tilt and glass, he's a lazy sod.
is200_turbo
Copper - Posts: 88
Posted: May 21, 2011 at 1:52 AM / IP Logged
No lol all the features of the alarm are fitted but the accessory outputs like lights window venting etc
As I only got the car 2 weeks ago I know very little about it and due to it being an import it's all on japaneese on the fuse box
Posted: May 21, 2011 at 2:44 AM / IP Logged
Those things are normally charged as extras anyway plus parts.
Look at a Primera, it's probably the same fusebox. I use that rick with Mitsubishis, N.B. probably got two or three under hood and one internal.
bala
Member - Posts: 18
Posted: March 02, 2014 at 3:35 PM / IP Logged
hi . Just bought a 2002 nissan stagea. Was going to install a cheap single immobiliser alarm. Brand:Kavass. The problem is the driver side door will only lock by the lock/unlock switch but it does not unlock when you use the same switch. Does this mean the door motor on the driver side is faulty or could it be wired some how. Please advise. Thanks
kaalz
howie (aka: harryharris)
Silver - Posts: 355
Posted: March 02, 2014 at 4:26 PM / IP Logged
Sounds like a faulty switch, wiring break, or unlock relay.
do all doors lock and unlock with the key or remote fob buttons.
Test before boxing up.
bala
Member - Posts: 18
Posted: March 02, 2014 at 6:13 PM / IP Logged
It locks with the key. when using the tag it only locks the other 3 pasenger doors. does not lock the driver door?
kaalz
