2005 cadillac escalade r/s wire info?
sled02brp
Posted: October 31, 2011 at 7:57 PM / IP Logged
I'm installing a Viper 5301 with a XK01 Interface in my 2005 Escalade. I cant find a tech sheet anywhere. Is there anyone out there with a tech sheet? Thanks!
Caleb L.
clarence1996
Member - Posts: 15
Posted: October 31, 2011 at 8:09 PM / IP Logged
2002-06 is the same
TheWire1
sled02brp
Posted: October 31, 2011 at 9:06 PM / IP Logged
All I see is info for 02 and older. 03 to 06 is the same. Starting in 03 GM trucks and full size SUV's needed a interface module that used data to lock/unlock doors. That info is not on the tech sheet for the 2002 model. Also the newer bypass mods will use data to bypass passlock2 or passkey3. Just need the tech sheet for 03 to 06. I found one for the 05 Yukon... But that has the 5.3 V8 not the Escalade 6.0 so I'm not sure what might be different in the wiring.
Caleb L.
