07 trailblazer passlock2 info?
davegamezjr
Posted: December 12, 2011 at 10:49 PM / IP Logged
Hello guys, needing advice on passlock 2. I've put RS units in vehicles atleast 10 times. Never had to use a bypass module due to the cars were always pre anti-theft era. My issue is how and where to read the resistor value on my truck? And does a 791 bypass unit from bulldog security all I need?
shortcircuit161
Silver - Posts: 556
Posted: December 30, 2011 at 11:32 AM / IP Logged
In the downloads section, search Passlock and you will see the diagram to test for resistance. The passlock wires are right under the ignition cylinder. I just did a 2006 Equinox and should be similar setup. There are several bypass units, I used the DEI PLJX and it worked great for the bypass function. There are also modules that will control more than just the bypass (locks, parking lights, alarm disarm) too.
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
