2003 Ford E-450 Super Duty Alarm/Remote Start Wiring
selmore
Posted: May 01, 2003 at 6:49 PM / IP Logged
I need a wiring diagram/cheat sheet for installing an alarm in an E-450.  Any help is appreciated.
Ronald Mark
Copper - Posts: 66
Posted: May 02, 2003 at 11:27 AM / IP Logged
This is 2002, newest I have
ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|yellow & lt. grn/pur|+ |ignition harness            |
|          STARTER|green               |+ |ignition harness            |
|        IGNITION|RED / lt. green       |+ |ignition harness            |
|        ACCESSORY|gry/yel & RED / blk   |+ |ignition harness            |
| SECOND ACCESSORY|blue/lt. green      |+ |ignition harness            |
|       POWER LOCK|*1                  |   |*1                          |
|     POWER UNLOCK|*1                  |   |*1                          |
|       LOCK MOTOR|pink/black          |   |VSM *2                      |
|     UNLOCK MOTOR|RED / orange          |   |VSM *2                      |
|    DISARM DEFEAT|pink/orange        |   |VSM *2                      |
| PARKING LIGHTS +|brown               |   |headlight switch            |
|       HEADLIGHTS|RED / yellow          |+ |headlight switch            |
|     DOOR TRIGGER|BLACK/ lt. blue      |+ |either kick panel           |
| DOME SUPERVISION|use door trigger    |   |                            |
| FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
|       TACHOMETER|*3                  |   |ignition coils              |
|      SPEED SENSE|gray/black          |   |instrument cluster or *4    |
|       BRAKE WIRE|lt. green           |+ |brake pedal switch          |
|     HORN TRIGGER|blue               |- |steering column or VSM *2   |
|           WIPERS|blue/orange        |- |steering column             |
| LF WINDOW UP/DN|wht/blk - tan/lt blu|A |driver window switch        |
| RF WINDOW UP/DN|wht/yel - tan/lt blu|A |driver kick panel           |
| LR WINDOW UP/DN|gry/org - yel/lt blu|A |driver kick panel           |
| RR WINDOW UP/DN|yel/blk - RED / blk   |A |driver kick panel           |
|        RADIO 12V|lt. GREEN/ purple    |+ |radio                      |
|     RADIO GROUND|BLACK/ lt. green     |- |radio                      |
|     RADIO SWITCH|pink               |+ |radio                      |
| RADIO ILLUMINATE|lt blue/red (dimmer)|+ |radio                      |
|       LF SPEAKER|org/lt grn-lt blu/wh|   |radio                      |
|       RF SPEAKER|wht/lt grn - grn/org|   |radio                      |
|       LR SPEAKER|gry/lt blu - tan/yel|   |radio                      |
|       RR SPEAKER|org/red - brn/pnk   |   |radio                      |
Notes:
*1 Without keyless entry use pink / YELLOW for lock and pink/lt. green for unlock. They are 5 wire reverse polarity mastered from the driver switch and found in either kick panel. With keyless entry use WHITE/ red for lock and BLACK/ white for unlock. They are negative trigger and found at the VSM. On the vehicles with keyless entry the GEM shuts down after the doors have been locked for a certain time period, to 'wake-up' the system refer to directfax document #1094. *2 The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening. *3 For tach go to any one of the ignition coils and use the wire that is NOT RED / lt. green. On diesel vehicles the tach wire is green or white, in a 42 pin plug under the clamp on the engine side of the air intake duct. On diesel vehicles the wait to start light is activated by a databus wire from the ECM. To do wait to start use a pulse timer relay and follow directfax document #1091. *4 Also found at the radio on vehicles that have the in-dash CD changer.
selmore
Posted: May 02, 2003 at 5:59 PM / IP Logged
So far so good!
selmore
Posted: May 07, 2003 at 5:23 PM / IP Logged
Apparently there were some changes from '02 to '03.  Here's what I have confirmed from my experience:
|              12V|yellow                  |+ |ignition harness            |
|       POWER LOCK|pink/black        |+|kick panel w/ non-remote    |
|     POWER UNLOCK|pink/brown       |+ |kick panel w/ non-remote   |
| PARKING LIGHTS |NOT brown?      |+ |headlight switch            |
Tuesday, April 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
