2008 town and country with subwoofer
watson7768
Posted: February 09, 2012 at 6:34 AM / IP Logged
wiring schematic for 2008 chyrsler town and country with subwoofer system and amp locations
reyhb
Member - Posts: 24
Posted: February 09, 2012 at 10:25 AM / IP Logged
     (Remote Start Wiring)
Battery LIGHT BLUE/RED (+) IGNITION SWITCH HARNESS **THIS WIRE ONLY SUPPLYS 10 AMPS OF CURRENT, FOR HIGH CURRENT APPLICATION GO DIRECTLRY TO THE BATTERY
     Ignition 1 PINK/WHITE (+) WIRELESS IGNITION MODULE IN STEERING COLUMN
     Starter 1        THIS VEHICLE USES THE CAN DATA NETWORK FROM THE WIRELESS IGNITION MODULE IN THE STEERING COLUMN FOR REMOTE START FUNCTIONS. USE AN APPROPRIATE ADAPTOR FROM A SECURITY MANUFACTURER FOR REMOTE START
     Anti-Theft Type DAIMLER SENTRY KEY® VEHICLE IMMOBILIZER
     Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Parking Lights WHITE/ LIGHT GREEN (L) & WHITE/ TAN (R) (+) AT TIPM MODULE ON DRIVERS SIDE OF ENGINE
     Brake Lights WHITE/ TAN (+) AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights WHITE/ LIGHT GREEN (+) AT TIPM UNDER HOOD
     Horn DARK GREEN/ VIOLET (-) IN HARNESS AT STEERING COLUMN
reyhb
Member - Posts: 24
Posted: February 09, 2012 at 10:44 AM / IP Logged
(Security)
     Battery LIGHT BLUE/RED(+)IGNITION SWITCH HARNESS … THIS WIRE ONLY SUPPLY'S 10 AMPS OF CURRENT, FOR HIGH CURRENT APPLICATION GO DIRECTLY TO THE BATTERY
     Ignition 1PINK/WHITE(+)WIRELESS IGNITION MODULE IN STEERING COLUMN
     Starter 1.. THIS VEHICLE USES THE CAN DATA NETWORK FROM THE WIRELESS IGNITION MODULE IN THE STEERING COLUMN FOR REMOTE START FUNCTIONS. USE AN APPROPRIATE ADAPTOR FROM A SECURITY MANUFACTURER FOR REMOTE START
     LF Latch VIOLET(-)AT TIPM MODULE ON DRIVERS SIDE OF ENGINE
     RF Latch VIOLET/WHITE(-)AT TIPM MODULE ON DRIVERS SIDE OF ENGINE
     LR Latch VIOLET/GRAY(-)AT TIPM MODULE ON DRIVERS SIDE OF ENGINE
     RR Latch VIOLET / YELLOW(-)AT TIPM MODULE ON DRIVERS SIDE OF ENGINE
     Trunk Trigger VIOLET(-)AT TIPM MODULE ON DRIVERS SIDE OF ENGINE
     Parking Lights WHITE/ LIGHT GREEN (L) & WHITE/ TAN (R)(+)AT TIPM MODULE ON DRIVERS SIDE OF ENGINE
****(Above with 4.0L engine, 6 Speaker System)****
****(Below With 3.3L engine, 4 Speaker System)****
(Security)
     Battery LIGHT BLUE/RED(+)IGNITION SWITCH HARNESS… THIS WIRE ONLY SUPPLY'S 10 AMPS OF CURRENT, FOR HIGH CURRENT APPLICATION GO DIRECTLY TO THE BATTERY
(Remote Start)
     Starter 1 1.. THIS VEHICLE USES THE CAN DATA NETWORK FROM THE WIRELESS IGNITION MODULE IN THE STEERING COLUMN FOR REMOTE START FUNCTIONS. USE AN APPROPRIATE ADAPTOR FROM A SECURITY MANUFACTURER FOR REMOTE START
     Anti-Theft Description THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Brake Lights WHITE/ TAN(+)AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights WHITE/ LIGHT GREEN(+)AT TIPM UNDER HOOD
     Horn DARK GREEN/ VIOLET(-)IN HARNESS AT STEERING COLUMN
reyhb
Member - Posts: 24
Posted: February 09, 2012 at 11:02 AM / IP Logged
(Audio) with 3.3L engine and 4 Speaker System
     Battery YELLOW/RED(+)RADIO HARNESS
     Accessory THIS VEHICLE USES THE CAN DATA SYSTEM FOR ACCESSORY TURN ON
     Ground BLACK/ WHITE(-)RADIO HARNESS
     LF Speaker (+)GRAY/VIOLET
     LF Speaker (-)GRAY / YELLOW
     RF Speaker (+)DARK GREEN/ VIOLET
     RF Speaker (-)DARK GREEN/ YELLOW
     LR Speaker (+)GRAY/LIGHT GREEN
     LR Speaker (-)GRAY/DARK GREEN
     RR Speaker (+)DARK GREEN/ LIGHT GREEN
     RR Speaker (-)DARK GREEN/ GRAY
     Steering Controls YES
     Speed Controls NO
     Radio Security YES
      (Audio) with 4.0L engine and 6 Speaker System
     Speed Controls NO
     Radio Security YES
Amp location is behind left quarter panel near sub-woofer***
