2011 ford econoline e350
smc0922
Member - Posts: 14
Posted: February 10, 2012 at 7:54 PM / IP Logged
Looking for remote start/security wiring info for a new Econoline 350. Thanks!
-Shawn
AIM: Creegman9695
reyhb
Member - Posts: 24
Posted: February 10, 2012 at 8:46 PM / IP Logged
Remote Start/Security
     Battery BLUE/RED(+)IGNITION SWITCH HARNESS   ** MAY BE GREEN/ RED ON STRIPPED CHASSIS
     Ignition 1WHITE/ ORANGE(+)IGNITION SWITCH HARNESS
     Accessory 1BROWN / YELLOW(+)IGNITION SWITCH HARNESS
     Accessory 2VIOLET/GREEN(+)IGNITION SWITCH HARNESS
     Starter 1BLUE/WHITE(+)IGNITION SWITCH HARNESS
     Key Sense BLUE/GRAY(-)IGNITION SWITCH HARNESS
     Tachometer GREEN/ BLUE(-)AT PCM MODULE ** ALSO AT INJECTOR #1
     Speed Sense VIOLET ORANGE(AC)AT PCM MODULE** ALSO IN HARNESS TO OVERHEAD CONSOLE
     Parking Lights VIOLET/WHITE(+)AT SMART JUNCTION BOX
     Low Crr. Pk Lights GRAY(-)VEHICLE LIGHT SWITCH
     Brake Lights VIOLET/WHITE(+)AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights BLUE/WHITE(+)IN HARNESS IN DRIVER KICKPANEL
     Horn BLUE/WHITE(-)HARNESS AT STEERING COLUMN
     All Door Trigger GRAY/VIOLET(+)IN HARNESS IN DRIVER KICK-PANEL** TO AVOID DOME-LIGHT DELAY USE INDIVIDUAL DOOR TRIGGERS AND DIODE ISOLATE EACH WIRE
     LF Latch GREEN/ VIOLET(-)IN HARNESS IN DRIVER KICKPANEL
     RF Latch WHITE(-)IN HARNESS IN DRIVER KICKPANEL
     RR Latch YELLOW(-)IN HARNESS IN DRIVER KICKPANEL
     Trunk Trigger GREEN(-)IN HARNESS IN DRIVER KICKPANEL** MONITORS REAR CARGO DOORS
     Low Crr Pk Lights GRAY(-)VEHICLE LIGHT SWITCH
