Mitsubishi Triton Mf Radio Harnesses AU
89triton
Posted: March 28, 2012 at 11:37 PM / IP Logged Link to Post Post Reply Quote 89triton
Build AUG 88
Budget cheap as I already have most everything maybe $20 for a harness
VIN JMFMF3M27JJoo144o Jan 89
It has extensive wiring problems which I have worked through successfully.
The radio harness has been cut out of the wiring loom.
I need a wiring diagram for this vehicle.
I have a mitsubishi radio from the era. MB649827 AR-4325 3410107
Need the pinouts for this
The vehicle appears to have common neg speaker grounds.With 1 wire in the loom blue/white which give 6 volts all the time,
when acc or run it gives 12 volts.
These are the wires that work and what they appear to do WHITE/ Blue L/F
BLACK/ Blue L/F BLACK/ Red R/F and of course the 1 blue/white which powers 6v/12v
1
- -- o- o-------o-------o--o-
|__|__|__|__|__|__|__|__|
------------------------------------Representation MB649827 Mitsubishi Radio
---------o--o-----------o---o------Pinout block rear of radio (o=Pins)
My interpretation starting at left top pin 1 through to 2nd line last pin 16
6v/12v wire operates radio pin 8 think pin 2 is ant RED / Black R/F Pin 13
BLACK/ Blue pin 5 WHITE/ Blue L/F pin 3
The radio goes but does not turn off until ign off.
1 Blue/white to the gigarette lighter 2 GREEN / WHITE Illumination
1 black wire left over in the wiring loom. When the lights go on it shows 9 volts
I cannot find the constant wire 12v+RED / Black So ihave built 1 off the loom.
I don't have any other clues.
I have had the vehicle ruinning, after rewiring the coil etc replacing subfuseable links
Everything is going now. Except lic plate and 1 parklight and the instrument night light.
Thank-you
Sunday, August 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
