02 Hyundai Accent Cruise Control Wiring
dbatch
Posted: May 13, 2003 at 9:38 AM / IP Logged
I am installing a cruise control but need to know which wire is the vss and which is the tach.  Does anyone have the color codes for a 2002 or 2001 accent?
the12volt
Administrator - Posts: 3,957
Posted: May 13, 2003 at 5:28 PM / IP Logged
VSS Wire: LOCATION 7 - DIAGNOSTIC CONNECTOR BELOW STEERING COLUMN
VSS Wire Color: WHITE/ BLACK
VSS Pulse: 4000
VSS Tach Wire: USE CLUTCH SWITCH 250-4206
Tach Signal Wire Color: NOT USED
Brake Switch Positive: RED / BLACK
Brake Switch Negative: GREEN / WHITE
View locations referred to above here: http://www.rostra.com/pdf/wirelocations.pdf
02 Hyundai Accent Cruise Control Wiring -- posted image. the12volt • Support the12volt.com
Tuesday, October 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
