2003 Infiniti G35 Sedan Alarm/Remote Start/Stereo Wiring
esmith69
Gold - Posts: 1,511
Posted: May 13, 2003 at 6:53 PM / IP Logged
Gonna be getting mine within the next month or so!2003 Infiniti G35 Sedan Alarm/Remote Start/Stereo Wiring -- posted image.
It comes with a simple factory keyless/alarm but how difficult would it be to install, say, a Clifford Matrix RS3 in it?  I know it has an immobilizer system in it, but I don't know specifics about the system or which bypass module it would need.  Also I was thinking of doing a proximity sensor as well.  Any wiring info/diagrams/advice you could give me for this vehicle would be much appreciated.
Ethan
Donate to the12volt.com
Patel
Copper - Posts: 86
Posted: May 13, 2003 at 7:17 PM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|WHITE/ blue          |+ |ignition harness            |
|          STARTER|WHITE/ red           |+ |ignition harness            |
|   SECOND STARTER|WHITE/ green        |+ |ignition harness            |
|        IGNITION|BLACK/ red           |+ |ignition harness            |
|        ACCESSORY|WHITE/ black        |+ |ignition harness            |
|       POWER LOCK|RED / white *1        |- |driver switch in door       |
|     POWER UNLOCK|blue/white *1       |- |driver switch in door       |
|       LOCK MOTOR|purple              |   |wht plug, pin 30 @ BCM *2   |
|     UNLOCK MOTOR|yellow              |   |wht plug, pin 23 @ BCM *2   |
|    DISARM DEFEAT|WHITE/ blue          |   |wht plug, pin 31 @ BCM *2   |
| PARKING LIGHTS +|RED / blue            |   |driver kick panel           |
|       HEADLIGHTS|RED / blk (L), red (R)|+ |wht 12 pin plug, IPDM E/R *3|
|     DOOR TRIGGER|*4                  |- |wht 12 pin plug @ BCM *2    |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|RED / white           |- |wht plug, pin 18 @ BCM *2   |
|        HOOD PIN|lt GREEN/ black      |- |pin switch under hood       |
|TRNK/HTCH RELEASE|blue               |- |brn plug, pin 76 @ BCM *2   |
| FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|*1                  |   |                            |
|       TACHOMETER|NOT black or wht/blu|   |any ignition coil           |
|      SPEED SENSE|WHITE/ green        |2 |cluster, brn plug, pin 19   |
|       BRAKE WIRE|pink/blue           |+ |brake pedal switch          |
|     HORN TRIGGER|GREEN/ black        |- |steering column             |
|           WIPERS|purple(L),blu/blk(H)|- |wiper motor                 |
| LF WINDOW UP/DN|*5                  |   |                            |
| RF WINDOW UP/DN|                    |   |                            |
| LR WINDOW UP/DN|                    |   |                            |
| RR WINDOW UP/DN|                    |   |                            |
| SUN RF OPN/CLOSE|not recommended     |   |                            |
|        RADIO 12V|yellow              |+ |radio                      |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|lt green            |+ |radio                      |
| RADIO ILLUMINATE|RED / blue            |+ |radio                      |
|    POWER ANTENNA|grn/wht or RED / wht |+ |radio                      |
|       LF SPEAKER|wt or bu-bk or bk/wt|   |radio or amplifier *6       |
|       RF SPEAKER|gn or br-re or bk/re|   |radio or amplifier *6       |
|       LR SPEAKER|br or l gn-y or bk/y|   |radio or amplifier *6       |
|       RR SPEAKER|bu or or-pk or bk/pk|   |radio or amplifier *6       |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U. *1 These are the driver door key cylinder wires. Meter the wires while turning the key in the driver door. Single pulse on the unlock wire will disarm the alarm without unlocking the doors. Unlock requires a double pulse. *2 The BCM (Body Control Module) is in the driver kick panel. *3 The IPDM E/R (Intelligent Power Distribution Module Engine Room) is between the passenger fender and the battery. *4 The driver door trigger is white in pin 14, the front passenger door is pink in pin 10, and the rear door trigger (on vehicles without navigation) is pink in pin 11. On vehicles with navigation system the rear door trigger wire does not go to the BCM, instead use 2 separate pink wires in the driver kick panel in the harness that runs to the rear. Use all wires and diode isolate each. *5 Extended triggers on the power door lock wires will roll the windows up and down. *6 The amplifier is under the rear deck.
esmith69
Gold - Posts: 1,511
Posted: May 13, 2003 at 10:27 PM / IP Logged
Thanks, I will let yall know what I decide to do once I finally get the car!2003 Infiniti G35 Sedan Alarm/Remote Start/Stereo Wiring -- posted image.
Ethan
Wednesday, December 10, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
