2006 kia rio5 remote start wiring
state
Posted: November 09, 2013 at 5:15 PM / IP Logged
I'm looking for a wiring diagram for a remote start on a 2006 Kia Rio5.
Thanks for any help,
State
Platinum - Posts: 12,488
Posted: November 10, 2013 at 3:30 PM / IP Logged
Battery     BLUE & GREEN     (+)     IGNITION SWITCH HARNESS
Ignition 1     PINK     (+)     IGNITION SWITCH HARNESS
Accessory 1     ORANGE     (+)     IGNITION SWITCH HARNESS
Accessory 2     YELLOW     (+)     IGNITION SWITCH HARNESS
Starter 1     WHITE     (+)     IGNITION SWITCH HARNESS
Key Sense     BLUE     (+)     IGNITION SWITCH HARNESS
All Doors     BLUE     (-)     AT VEHICLE UNDER DASH FUSEBOX
Front Left Door     GREEN     (-)     HIGH IN DRIVER KICKPANEL ALL INDIVIDUAL DOOR TRIGGERS ARE COMMONLY WIRED
Dome Light Supervision     BLUE     (-)     AT VEHICLE FUSEBOX
Hood Trigger     BROWN     (-)     AT BCM MODULE UNDER CENTER OF DASH NEAR FIREWALL
Trunk/Hatch     GREEN/ ORANGE     (-)     AT BCM MODULE UNDER CENTER OF DASH NEAR FIREWALL
All Parking Lights     RED     (-)     AT VEHICLE LIGHT SWITCH HARNESS
Brake Lights     RED / ORANGE     (+)     AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights     WHITE/ BLACK     (+)     AT VEHICLE FUSEBOX
Power Lock     BLUE     (-)     IN HARNESS IN DRIVER KICKPANEL
Power Unlock     YELLOW/BLACK     (-)     IN HARNESS IN DRIVER KICKPANEL
Factory Alarm Disarm     WHITE/ BLACK     (-)     AT BCM MODULE UNDER CENTER OF DASH NEAR FIREWALL     20 PIN PLUG PIN 4
Horn     BLUE     (-)     IN HARNESS AT STEERING COLUMN
Parking Brake     GREEN/ ORANGE     (-)     AT VEHICLE PARKING BRAKE SWITCH
Front Left Window Up     GREEN     (REV)     AT MASTER WINDOW CONTROL SWITCH
Front Left Window Down     ORANGE     (REV)     AT MASTER WINDOW CONTROL SWITCH
Front Right Window Up     BROWN     (REV)     AT MASTER WINDOW CONTROL SWITCH
Front Right Window Down     GRAY     (REV)     AT MASTER WINDOW CONTROL SWITCH
Rear Left Window Up     YELLOW     (REV)     AT MASTER WINDOW CONTROL SWITCH
Rear Left Window Down     WHITE     (REV)     AT MASTER WINDOW CONTROL SWITCH
Rear Right Window Up     GREEN     (REV)     AT MASTER WINDOW CONTROL SWITCH
Rear Right Window Down     BLUE     (REV)     AT MASTER WINDOW CONTROL SWITCH
Low Speed Wipers     GREEN     (+)     AT VEHICLE FUSEBOX
Tach     GREEN     (AC)     IN HARNESS TO GAUGES
Speed Sense     RED / ORANGE     (AC)     AT DATALINK CONNECTOR UNDER DASH
state
Posted: November 11, 2013 at 8:29 AM / IP Logged
Thanks!
