2012 base model impala remote starter
BigMotor
Posted: November 24, 2013 at 6:03 PM / IP Logged
Did some research in your forums and didn't find any information about a remote start system for this vehicle. Is there such a thing?
Platinum - Posts: 7,827
Posted: November 24, 2013 at 8:30 PM / IP Logged
Yes, there is.  Any current model, quality brand, remote starter will work.
Here is a link to the vehicle wiring :
http://diagrams.marktoonen.nl/printlist.aspx?MakeID=13&ModelID=20282
Your car should have the Passkey3+ immobilizer system.  The factory keys will have a "+" sign inside of a circle
at the top of the metal key blade.
You will also need a bypass module.  For the DIYer look at the Fortin PATS GM2 bypass module ( there are many other
brands / models available ).  This module comes ready to go right out of the box, no special cable or on-line programming
necessary.  Here is a link to the install guide : https://ifar.ca/download/4401/pats-gm2_installation_guide.rev-20120430.pdf
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
