2001 Honda Civic Alarm
audio Xclusive
Member - Posts: 30
Posted: June 16, 2002 at 8:51 PM / IP Logged
Need alarm info for 2001 Honda Civic
another Xclusive installation
Platinum - Posts: 12,488
Posted: June 16, 2002 at 9:43 PM / IP Logged
Honda
Civic
2001-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE
IGNITION SWITCH HARNESS **
Ignition  #1:
BLACK / YELLOW
Ignition #2:
BLACK/ RED
Ignition  #3:
N/A
Accessory:
WHITE/ RED
Brake  Light:
WHITE/ BLACK
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLUE
IN 2-PIN PLUG AT PASSENGER SIDE OF BATTERY
Parking Lights:
RED / BLACK (+)
AT BACK OF FUSE BOX
Headlights:
BLUE/RED (-)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
OEM Alarm  Arm:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * This vehicle is equipped with a transponder immobilizer system;
Honda
Civic
2001-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE
Starter  Kill:
BLACK/ WHITE
Ignition  +12 Volts:
BLACK / YELLOW
Dome  Lights/Superv:
SEE NOTE BELOW
OEM Horn:
ORANGE (-)
STEERING COLUMN HARNESS
Power  Lock:
WHITE/ BLUE (-)
GRAY PLUG ABOVE DRIVER'S KICK PANEL
Power  Unlock:
WHITE/ GREEN (-)
Trunk  Release:
N/A
Alarm  Input Wire:
SEE NOTE BELOW
Notes:
** The Driver's Door Trigger Is Green (-), Front Passenger Door Trigger Is Lt. GREEN/ Red (-), Rear Doors Trigger Is GREEN / WHITE (-). The Wires Are Found In The Alarm Plug In A Green Plug Above The Driver's Kick Panel.
audio Xclusive
Member - Posts: 30
Posted: June 17, 2002 at 12:46 AM / IP Logged
what does it mean when the vehicle is equiped w/ a transponder immoblilizer system
and thanks for the info
Posted: June 17, 2002 at 6:19 AM / IP Logged
That means that the Civic has an anti theft system that requires the bypassing of a small resistor chip in the head of the key. When the key is inserted into the key cylinder that has the proper resistance , the anti theft system unlocks the ignition system and activates the fuel pump and injectors to allow the car to start. Without the proper resistance, the car will not start. This is only necessary if you are installing a remote starter. If you are only installing an alarm, you do not need this bypass module.
audio Xclusive
Member - Posts: 30
Posted: June 17, 2002 at 6:23 AM / IP Logged
It is a remote start alarm as a matter of fact it's the crime stopper cs 2011rs.  Where can I get this bypass module.
Posted: June 17, 2002 at 6:39 AM / IP Logged
You can get it from us or you can get it from any Best Buy or Radio Shack. We sell these for $ 45.00 USD and these are the KEYLESS versions where you do not need a spare key as the bypass so you do not need to worry about a spare key in the car.
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
