2014 Hyundai Accent Alarm/Remote Start/Stereo Wiring
bency
Posted: January 06, 2015 at 1:51 AM / IP Logged
Hi,
I am looking for complete wiring diagram of Hyundai Accent 2014 or its called as Verna Fluidic in India.
Ben
tonanzith
Gold - Posts: 603
Posted: January 06, 2015 at 2:15 PM / IP Logged
This is the American wiring. Yours may be a bit different so definitely verify connections using a meter.
12 Volts     green (40A)     +     ignition switch, black 6 pin plug, pin 1
Second 12 Volts     blue (40A)     +     ignition switch, black 6 pin plug, pin 5
Starter     white     +     ignition switch, black 6 pin plug, pin 3
Second Starter     N/A
Ignition     pink     +     ignition switch, black 6 pin plug, pin 4
Second Ignition     N/A
Third Ignition     N/A
Accessory     orange     +     ignition switch, black 6 pin plug, pin 2
Second Accessory     yellow     +     ignition switch, black 6 pin plug, pin 6
Third Accessory     N/A
Keysense     blue/orange     -     ignition key switch, white 6 pin plug, pin 4
Data Bus     blue/org (immobilizer data); yellow (immob. light)     data; - lt     left of dash fuse box, black 21 pin plug, pins 11, 3
Can Bus High     green (C-CAN)     data     data link connector, black 16 pin plug, pin 6
Can Bus Low     orange (C-CAN)     data     data link connector, black 16 pin plug, pin 14
Can Bus Sw     N/A
Power Lock     brown (w/BCM); (w/o BCM add actuator in driv door)     -     driver kick, white 39 pin plug, pin 15
Power Unlock     gray (w/BCM); (w/o BCM add actuator in driv door)     -     driver kick, white 39 pin plug, pin 16
Lock Motor     gray (models with BCM)     5 wire     dash fuse box, white 42 pin plug (F), pin 22
Driver Unlock Motor     brown (models with BCM)     5 wire     dash fuse box, white 42 pin plug (F), pin 40
Passenger Unlock Motor     brown (models with BCM)     5 wire     dash fuse box, white 42 pin plug (F), pin 26
Parking Lights (-)     pink/black or orange     -     headlight switch, wht 14 pin plug, pin 7, or wht 13 pin plug, pin 1
Parking Lights (+)     GREEN/ black (L); yellow/black (R)     +     dash fuse box, white 42 pin plug (F), pins 35, 34
Hazards     blue/black (models with BCM)     -     BCM above gas pedal, white 20 pin plug, pin 4
Turn Signal (Left)     green     +     dash fuse box, white 42 pin plug (F), pin 38
Turn Signal (Right)     blue     +     dash fuse box, white 42 pin plug (F), pin 31
Headlight     pink/black (LO); pnk or wht (HI) (w/ign on only)     -     headlight sw, wht 14 pin plg, pins 12, 13, or wht 13 pin plg, pins 4, 9
AutoLights     green (interrupt to turn off autolights)     -     headlight switch, white 13 pin plug, pin 3
Reverse Light     green     +     driver kick, white 39 pin plug, pin 39
Left Front Door Trigger     BROWN / orange     -     driver kick, white 39 pin plug, pin 2
Right Front Door Trigger     pink     -     driver kick, white 39 pin plug, pin 1
Left Rear Door Trigger     (same as right front door trigger)
Right Rear Door Trigger     (same as right front door trigger)
Dome Supervision     (same as right front door trigger)
Trunk/Hatch Pin     green     -     driver kick, white 39 pin plug, pin 25
Rear Glass Pin     N/A
Hood Pin     N/A
Trunk/Hatch Release     (locks/unlocks along with doors on hatchback)
Trunk Release Motor     N/A
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     N/A
Factory Alarm Disarm     gray/org (key unlock); blue/blk (unlock detection)     both dbl -     driver kick, white 39 pin plug, pins 12, 38
Disarm No Unlock     N/A
Trunk Alarm Shunt     N/A
Tachometer     BROWN / white, green, pink, or green     ac     front of engine, black 12 pin plug, pin 1, 3, 5, or 7
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     pink     +     clutch switch, white 2 pin plug, pin 2
Fuel Pump     brown     +     above driver kick, white 22 pin plug, pin 6
Rear Defroster     white     -     rear defogger sw, black 6 pin plug, pin 4, or white 12 pin plug, pin 10
Mirror Defroster     (mirror same as rear defrost); blue (front deicer)     -     front deicer switch, black 6 pin plug, pin 4
Left Front Heated Seat     gray/orange     +     driver kick, white 39 pin plug, pin 26
Right Front Heated Seat     ORANGE / black     +     passenger kick, white 22 pin plug, pin 4
Speed Sense     pink     4-Pulse     data link conn, blk 16 pin plug, pin 3, or radio, wht 24 pin plug, pin 16
Brake Wire     red     +     above driver kick, white 22 pin plug, pin 7
Parking Brake     green     -     dash fuse box, white 42 pin plug (F), pin 32
Horn Trigger     blue     -     left of dash fuse box, black 21 pin plug, pin 9
Wipers     green (LO); white (HI); brown (ignition)     +     wiper sw, blk 14 pin plg, pins 4, 2, 3, or wht 14 pin plg, pins 3, 9, 10
Left Front Window (Up/Down)     green - orange (with auto down only)     A     power window main switch, white 16 pin plug, pins 8 - 7
Right Front Window (Up/Down)     brown - gray     A     driver kick, harness to rear
Left Rear Window (Up/Down)     yellow - white     A     driver kick, harness to rear
Right Rear Window (Up/Down)     green - blue     A     driver kick, harness to rear
Sun Roof (Open/Close)     red - gray (function with ignition on only)     -     sunroof switch, black 6 pin plug, pins 2 - 3
Sun Roof (Limit/Close)     N/A
Memory Seat 1     N/A
Memory Seat 2     N/A
Memory Seat 3     N/A
Radio 12V     red     +     radio, white 24 pin plug, pin 12
Radio Ground     black     -     radio, white 24 pin plug, pin 24
Radio Ignition     yellow     +     radio, white 24 pin plug, pin 11
Radio Illumination     yellow (parking lights); BLACK/ orange (dimmer)     +,-     radio, white 18 pin plug, pins 8, 17
Factory Amp Turn-on     N/A
Power Antenna     pink     +     radio, white 18 pin plug, pin 18
Left Front Speaker (+/-)     white - brown     +,-     radio, white 18 pin plug, pins 2 - 11
Right Front Speaker (+/-)     yellow - black     +,-     radio, white 18 pin plug, pins 3 - 12
Left Rear Speaker (+/-)     red - blue     +,-     radio, white 18 pin plug, pins 1 - 10
Right Rear Speaker (+/-)     blue - orange     +,-     radio, white 18 pin plug, pins 4 - 13
Center Channel (+/-)     N/A
Subwoofer (+/-)     N/A
Aux. Audio Input Left (+/-)     white - BLACK/ orange     +,-     radio, white 24 pin plug, pins 21 - 9
Aux. Audio Input Right (+/-)     green - BLACK/ orange     +,-     radio, white 24 pin plug, pins 8 - 9
RSE Video (+/-)     N/A
RSE Audio Left (+/-)     N/A
RSE Audio Right (+/-)     N/A
Satellite Radio 12 Volts     (built into radio)
Satellite Radio Ground     N/A
Satellite Radio Ignition     N/A
Satellite Radio Antenna     N/A
Satellite Audio Left (+/-)     N/A
Satellite Audio Right (+/-)     N/A
Item     Size     Depth     Location
Headunit     irregular center of dash
Left Front Speaker     6.5 left front door
Left Front Tweeter   left front door
Right Front Speaker     6.5 right front door
Right Front Tweeter   right front door
Left Rear Speaker     6.5 left rear door
Left Rear Tweeter     N/A
Right Rear Speaker     6.5 right rear door
Right Rear Tweeter     N/A
Center Channel     N/A
Subwoofer     N/A
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner     (built into radio)
Gary Sather
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
