power door locks, 2010 dodge quad cab
jaybob
Posted: March 02, 2015 at 8:13 PM / IP Logged Link to Post Post Reply Quote jaybob
I need a power door lock wiring diagram for a 2010 dodge quad cab
Platinum - Posts: 7,827
Posted: March 02, 2015 at 8:37 PM / IP Logged Link to Post Post Reply Quote kreg357
Here is a link to the 451m Door Lock module :   https://www.the12volt.com/installbay/file.asp?ID=726
Use a 451M module and the Type H diagram with a 330 ohm resistor for Lock and a 110 ohm resistor for Unlock.   Connect the outputs to
this vehicle wire in the passenger door :
Power Locks    PURPLE / Light Green    @ passenger door lock switch, Green 10 pin plug, pin 8
Friday, September 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
