radio amp turn on
bball50usa
Posted: June 22, 2016 at 11:16 AM / IP Logged Link to Post Post Reply Quote bball50usa
wired in new radio with aftermarket connector, have no audio.
install factory unit, ok.
no amp turn on from new head unit, nothing here for amp turn on wire.
please help.
98 Cadillac Deville, non bose
bball50usa
geepherder
Platinum - Posts: 3,668
Posted: June 22, 2016 at 12:50 PM / IP Logged Link to Post Post Reply Quote geepherder
Grab a basic test light. With the aftermarket deck plugged in, but not installed in the dash, turn the key to the on position. Now, connect the alligator clip of the test light to 12 volts, and back probe any remaining wires (not currently used) in the factory plug one at a time and see if you get sound.
icearrow6
Copper - Posts: 497
Posted: June 22, 2016 at 1:06 PM / IP Logged Link to Post Post Reply Quote icearrow6
What harness part did you use?
sparkie
Platinum - Posts: 2,061
Posted: June 22, 2016 at 3:51 PM / IP Logged Link to Post Post Reply Quote sparkie
The factory amp is turned on and controlled through data. You need to use a radio replacement module that will turn on the amp.
sparky
bball50usa
Posted: June 22, 2016 at 3:58 PM / IP Logged Link to Post Post Reply Quote bball50usa
ah, just as I thought. do not have the availability to diagrams and info I had before I retired.
thank you.
bball50usa
Thursday, January 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
