2015 Hyundai Sonata Stereo Wiring
advent
Posted: July 23, 2016 at 2:45 PM / IP Logged
Hylloo all. Just trying to find the plug/audio wiring diagram for a 2015 Sonata. Looking to wire an amp/subs and all that fun shtuff. >__< Much obliged!
lurch228
Silver - Posts: 1,338
Posted: July 24, 2016 at 6:22 PM / IP Logged
Verify wiring colors for you 2015 to the 2014 listed below.
  • 2014 Hyundai Sonata Car Stereo Installation Guide
  • Car Radio Battery Constant 12V+ Wire: Red
  • Car Radio Accessory Switched 12V+ Wire: Blue
  • Car Radio Ground Wire: Black
  • Car Radio Illumination Wire: Blue
  • Car Radio Dimmer Wire: Gray
  • Car Radio Antenna Trigger Wire: Red
  • Car Radio Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A
  • Car Audio Front Tweeter Size: 3 1/2″ Tweeters
  • Car Audio Front Tweeter Depth: 2-1/2″
  • Car Audio Front Tweeter Location: N/A
  • Left Front Speaker Positive Wire (+): Orange
  • Left Front Speaker Negative Wire (-): Blue
  • Right Front Speaker Positive Wire (+): Blue/Orange
  • Right Front Speaker Negative Wire (-): Yellow/Orange
  • Car Audio Front Speakers Size: 6 1/2″ Speakers
  • Car Audio Front Speakers Depth: 3-1/5″
  • Car Audio Front Speakers Location: N/A
  • Left Rear Speaker Positive Wire (+): Pink
  • Left Rear Speaker Negative Wire (-): Green Right
  • Rear Speaker Positive Wire (+): Brown Right
  • Rear Speaker Negative Wire (-): White
  • Car Audio Rear Speakers Size: 6 1/2″ Speakers
  • Car Audio Rear Speakers Depth: 3-2/5″
  • Car Audio Rear Speakers Location: N/A
  • Car Subwoofer Speaker Positive Wire (+): N/A
  • Car Subwoofer Speaker Negative Wire (-): N/A
  • Car Subwoofer Speaker Size: N/A
  • Car Subwoofer Speaker Depth: N/A
  • Car Subwoofer Speaker Location: N/A
advent
Posted: July 25, 2016 at 11:24 AM / IP Logged
Thanks a bunch! I was testing the the factory harness for accessory/ignition wire and I found a GRN wire, any idea what that might've been? It may have been GRN/BLK I'm not 100% sure.
lurch228
Posted: July 25, 2016 at 3:52 PM / IP Logged
These are the 2014 Ignition switch wires check them to verify they are the same for you 2015
Vehicle Battery Positive Wire (+): Green
Vehicle Battery Positive Wire Location: Ignition Switch Harness
Vehicle Ignition Wire (+): Pink
Vehicle Ignition Wire Location: Ignition Switch Harness
Vehicle Second Ignition Wire (+): Orange
Vehicle Second Ignition Wire Location: Ignition Switch Harness
Vehicle Accessory Wire (+): Blue
Vehicle Accessory Wire Location: Ignition Switch Harness
frank_30
Member - Posts: 26
Posted: July 28, 2016 at 5:24 PM / IP Logged
2015 Hyundai Sonata (Smart Key)
Radio 12V     RED / black     +     radio, white 24 pin plug, pin 12
Radio Ground     black     -     radio, white 24 pin plug, pin 24
Radio Ignition     GREEN/ black     +     radio, white 24 pin plug, pin 11 or 18
Radio Illumination     blue (parking lights); gray (dimmer)     +,-     radio, white 18 pin plug, pins 8, 17
Factory Amp Turn-on     (M-CAN)
Power Antenna     red     +     radio, white 18 pin plug, pin 18
Left Front Speaker (+/-)     red - blue     +,-     radio, white 18 pin plug, pins 2 - 11
On models with amplifier, the speaker wires are red - blue at the amplifier in trunk right side, white 12 pin plug, pins 1 - 7 (JBL) or black 28 pin plug, pins 26 - 25 (MOBIS). The tweeter wires are red - blue at the amplifier, white 22 pin plug, pins 1 - 12 (JBL) or black 28 pin plug, pins 3 - 4 (MOBIS).
Right Front Speaker (+/-)     green - orange     +,-     radio, white 18 pin plug, pins 3 - 12
On models with amplifier, the speaker wires are green - orange at the amplifier in trunk right side, white 12 pin plug, pins 2 - 8 (JBL) or black 28 pin plug, pins 28 - 27 (MOBIS). The tweeter wires are brown - white at the amplifier, white 22 pin plug, pins 2 - 13 (JBL) or black 28 pin plug, pins 1 - 2 (MOBIS).
Left Rear Speaker (+/-)     white - black     +,-     radio, white 18 pin plug, pins 1 - 10
On models with amplifier, the speaker wires are white - black at the amplifier in trunk right side, white 12 pin plug, pins 3 - 9 (JBL) or black 28 pin plug, pins 15 - 14 (MOBIS).
Right Rear Speaker (+/-)     brown - white     +,-     radio, white 18 pin plug, pins 4 - 13
On models with amplifier, the speaker wires are brown - white at the amplifier in trunk right side, white 12 pin plug, pins 4 - 10 (JBL) or black 28 pin plug, pins 13 - 12 (MOBIS).
Center Channel (+/-)     red - blue (JBL)     +,-     amplifier in trunk right side, white 12 pin plug, pins 5 - 11
Subwoofer (+/-)     white - brown (JBL)     +,-     amplifier in trunk right side, white 12 pin plug, pins 6 - 12
On models with MOBIS amplifier, the subwoofer wires are white - brown (1); blue - red (2) at the amplifier in trunk right side, black 28 pin plug, pins 16 - 17; 18 - 19.
Aux. Audio Input Left (+/-)     black - BLACK/ orange or red - BLACK/ orange     +,-     radio, white 24 pin plug, pins 21 - 9
Aux. Audio Input Right (+/-)     white - BLACK/ orange or black - BLACK/ orange     +,-     radio, white 24 pin plug, pins 8 - 9
RSE Video (+/-)     green - white (rear view camera video)     +,-     radio, wh 16P plg, pins 4-3; wh 24P plg, pins23-22
Satellite Radio 12 Volts     (built into radio)
"throw it in the gutter and go buy another"
