2016 Toyota Tacoma Smart Key Alarm/RS/Stereo Wiring
lurch228
Silver - Posts: 1,338
Posted: September 11, 2016 at 9:54 PM / IP Logged
2016 Toyota Tacoma (Smart Key) - Wire Sheet
Item     Wire Color     Polarity     Wire Location     Note
12 Volts     black (50A)     +     dash fuse box, white 1 pin plug (1L), pin 1
Second 12 Volts     N/A
Starter     purple     +     Certification ECU right of dash fuse box, white 16 pin plug, pin 10
Second Starter     beige (SS1); gray (SS2)     -     Certification ECU right of dash fuse box, black 24 pin plug, pins 16, 18
Ignition     black     +     Certification ECU right of dash fuse box, white 16 pin plug, pin 3
Second Ignition     N/A
Third Ignition     N/A
Accessory     red     +     Certification ECU right of dash fuse box, black 24 pin plug, pin 9
Second Accessory     N/A
Third Accessory     N/A
Keysense     lt. green     -     Certification ECU right of dash fuse box, white 16 pin plug, pin 8
Data Bus     yellow (IMO); lt. blue (IMI)     data     Certification ECU right of dash fuse box, white 16 pin plug, pins 7, 6     Note 1
Can Bus High     blue     data     data link connector, white 16 pin plug, pin 6
Can Bus Low     white     data     data link connector, white 16 pin plug, pin 14
Can Bus Sw     black (RDA keyless entry data)     data     Body ECU on dash fuse box, white 30 pin plug, pin 4
Power Lock     red (w/o window jam protect); pink (w/jam protect)     -     driv kick, wh 13 pin plg, pin 9; dash FB, rear, wht 32 pin plg(1D), pin 10     Note 2
Power Unlock     yellow (w/o jam protect); yellow (w/jam protect)     -     drv kick, wh 13 pin plg, pin10; dash FB, rear, wht 32 pin plg(1D), pin 26     Note 3
Lock Motor     blue     5 wire     driver kick, gray 10 pin plug, pin 9
Driver Unlock Motor     black     5 wire     driver kick, gray 10 pin plug, pin 10
Passenger Unlock Motor     green     5 wire     dash fuse box, rear, white 32 pin plug (1D), pin 3
Parking Lights (-)     green     -     Body ECU on dash fuse box, white 30 pin plug, pin 22
Parking Lights (+)     green     +     dash fuse box, white 32 pin plug (1F), pin 3
Hazards     yellow     -     A/C Control Assembly, black 16 pin plug, pin 4
Turn Signal (Left)     beige (F); yellow (R)     +     above driv kick, blk 18P plg, pin 18; dash FB, wht 32 pin plg (1F), pin 6
Turn Signal (Right)     lt. blue (F); lt. blue (R)     +     above pass kick, wh 13P plg, pin13; dash FB, wht 32 pin plg (1F), pin 7
Headlight     yellow     -     Body ECU on dash fuse box, white 30 pin plug, pin 12
AutoLights     white (interrupt to turn off autolights)     -     Body ECU on dash fuse box, white 30 pin plg, pin 8
Reverse Light     red     +     above driver kick, white 18 pin plug, pin 5
Left Front Door Trigger     yellow     -     Body ECU on dash fuse box, white 30 pin plug, pin 6
Right Front Door Trigger     lt. green     -     Body ECU on dash fuse box, wht 30 pin plug, pin 27
Left Rear Door Trigger     pink     -     dash fuse box, white 36 pin plug (1H), pin 36
Right Rear Door Trigger     purple     -     dash fuse box, rear, white 32 pin plg (1D), pin 30
Dome Supervision     beige     -     dash fuse box, rear, white 32 pin plug (1D), pin 29
Trunk/Hatch Pin     N/A
Rear Glass Pin     N/A
Hood Pin     purple     -     Body ECU on dash fuse box, white 30 pin plug, pin 11
Trunk/Hatch Release     N/A
Trunk Release Motor     N/A
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     lt. blue (driver door key lock)     -     driver kick, white 13 pin plug, pin 11
Factory Alarm Disarm     green (driver door key unlock)     double -     driver kick, white 13 pin plug, pin 12
Disarm No Unlock     (smart key and push-button)
Trunk Alarm Shunt     N/A
Tachometer     beige     ac     data link connector, white 16 pin plug, pin 9
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     N/A
Fuel Pump     pink     +     below underhood fuse box, black 12 pin plug, pin 1
Rear Defroster     N/A
Mirror Defroster     black     (+) latched     driver kick, white 10 pin plug, pin 4
Left Front Heated Seat     red     +     driver kick, white 18 pin plug, pin 10
Right Front Heated Seat     lt. blue     +     passenger kick, white 18 pin plug, pin 7
Speed Sense     purple     ac     radio, white 28 pin plug, pin 17
Brake Wire     blue or lt. blue     +     brake switch, white 4 pin plug, pin 1
Parking Brake     white     -     dash fuse box, rear, white 32 pin plug (1D), pin 21
Horn Trigger     red to blue     -     horn switch or dash fuse box, white 32 pin plug (1F), pin 26
Wipers     black (LO); green (HI); blue (ignition)     +     wiper switch, white 10 pin plug, pins 3, 4, 2
Left Front Window (Up/Down)     lavender/blue - lavender/brown(w/o jam protection)     A     power window master switch, white 18 pin plug, pins 3 - 4
Right Front Window (Up/Down)     green - purple (w/o jam protection)     A     driver kick, gray 10 pin plug, pins 3 - 4
Left Rear Window (Up/Down)     lt. green - yellow     A     driver kick, gray 10 pin plug, pins 8 - 7
Right Rear Window (Up/Down)     black - red     A     driver kick, gray 10 pin plug, pins 6 - 2
Sun Roof (Open/Close)     black - lt. blue (function with ignition on only)     -     roof console assembly, white 24 pin plug, pins 19 - 18
Sun Roof (Limit/Close)     N/A
Memory Seat 1     N/A
Memory Seat 2     N/A
Memory Seat 3     N/A
Radio 12V     white     +     radio, white 10 pin plug, pin 4
Radio Ground     WHITE/ black     -     radio, white 10 pin plug, pin 7
Radio Ignition     gray     +     radio, white 10 pin plug, pin 3
Radio Illumination     green (parking lights); beige (dimmer)     +,-     radio, white 10 pin plug, pin 10; blue 6 pin plug, pin 5
Factory Amp Turn-on     N/A
Power Antenna     N/A
Left Front Speaker (+/-)     lavender/black - lavender/white     +,-     radio, white 10 pin plug, pins 2 - 6     Note 4
Right Front Speaker (+/-)     lavender/red - lavender/green     +,-     radio, white 10 pin plug, pins 1 - 5     Note 5
Left Rear Speaker (+/-)     white - black     +,-     radio, blue 6 pin plug, pins 2 - 6     Note 6
Right Rear Speaker (+/-)     blue - lt. green     +,-     radio, blue 6 pin plug, pins 1 - 3     Note 7
Center Channel (+/-)     N/A
Subwoofer (+/-)     lvndr/grn - lvndr/yel(1); lvndr/blk - lvndr/red(2)     +,-     amplifier on pass side rear cabin wall, wh 12 pin plg, pins 5-12; 4-10
Aux. Audio Input Left (+/-)     black - red     +,-     radio, white 28 pin plug, pins 28 - 27
Aux. Audio Input Right (+/-)     white - red     +,-     radio, white 28 pin plug, pins 26 - 27
RSE Video (+/-)     red - white (rear view camera video)     +,-     radio, white 24 pin plug, pins 12 - 24
RSE Audio Left (+/-)     N/A
RSE Audio Right (+/-)     N/A
Satellite Radio 12 Volts     red     +     satellite tuner below radio, wht 8 pin plug, pin 4
Satellite Radio Ground     black     -     satellite tuner below radio, wht 8 pin plug, pin 8
Satellite Radio Ignition     yellow     +     satellite tuner below radio, wht 8 pin plug, pin 3
Satellite Radio Antenna     (coaxial cable)
Satellite Audio Left (+/-)     (DIN cable)
Satellite Audio Right (+/-)     (DIN cable)
Headunit     double DIN center of dash
Left Front Speaker   left front door
Left Front Tweeter   left front dash
Right Front Speaker   right front door
Right Front Tweeter   right front dash
Left Rear Speaker   left rear door
Left Rear Tweeter     N/A
Right Rear Speaker   right rear door
Right Rear Tweeter     N/A
Center Channel     N/A
Subwoofer   passenger side rear cabin wall
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner   below radio
NOTES
1.The security light is purple (+) at the Certification ECU right of dash fuse box, black 24 pin plug, pin 19.
2.Test with passenger door switch on models with window jam protection.
3.Test with passenger door switch on models with window jam protection.
4.On models with amplifier, the speaker wires are green - lt. green (woofer); yellow - red (tweeter) at the amplifier on passenger side rear cabin wall, white 12 pin plug, pins 2 - 1; black 10 pin plug, pins 8 - 7.
5.On models with amplifier, the speaker wires are gray - blue (woofer); pink - purple (tweeter) at the amplifier on passenger side rear cabin wall, white 12 pin plug, pins 9 - 3; black 10 pin plug, pins 2 - 6.
6.On models with amplifier, the speaker wires are white - black at the amplifier on passenger side rear cabin wall, black 10 pin plug, pins 3 - 9.
7.On models with amplifier, the speaker wires are lavender/blue - lavender/lt. green at the amplifier on passenger side rear cabin wall, black 10 pin plug, pins 10 - 4.
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
