2003 Excursion 6.0L - Remote Start/Bypass
marylegz
Posted: December 04, 2016 at 2:26 PM / IP Logged Link to Post Post Reply Quote marylegz
Looking for as much information as I can find on a 2003 Ford Excursion 6.0l (diesel). I'll be working on installing a Viper 4806v with a 556u bypass module. I've found some diagrams for 2002 and 2004, but not too much for the 2003 model or the 4806v. Any help is appreciated! Thanks in advance.
Platinum - Posts: 13,726
Posted: December 04, 2016 at 4:00 PM / IP Logged Link to Post Post Reply Quote i am an idiot
It will be the same wiring as the 04. The 02 would have the 7.3 liter.
Posted: December 04, 2016 at 4:06 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Power Connections
     Wire Color     Polarity     Location     Plug/Pin #     Note     Picture
Battery     YELLOW     (+)     IGNITION SWITCH HARNESS
Ignition 1     RED / BLACK     (+)     IGNITION SWITCH HARNESS
Ignition 2     GRAY / YELLOW     (+)     IGNITION SWITCH HARNESS
Accessory 1     BLACK/ LIGHT GREEN     (+)     IGNITION SWITCH HARNESS
Starter 1     RED / LIGHT BLUE     (+)     IGNITION SWITCH HARNESS
Key Sense     BLACK/ PINK     (-)     IGNITION SWITCH HARNESS
Triggers
All Doors     BLACK/ LIGHT BLUE     (+)     IN HARNESS IN DRIVERS KICKPANEL
Trunk/Hatch     WHITE/ VIOLET     (-)     AT MODULE TO LEFT OF STEERING COLUMN
Lighting
All Parking Lights     BROWN     (+)     AT VEHICLE LIGHT SWITCH
Low Beam Headlights     RED / YELLOW     (+)     AT VEHICLE LIGHT SWITCH
Brake Lights     LIGHT GREEN     (+)     AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights     BLACK/ PINK     (+)     AT CENTRAL JUNCTION BOX IN DRIVER KICKPANEL
Integration
Power Lock     PINK / YELLOW     (-)     IN GRAY PLUG TO RIGHT OF STEERING COLUMN VEHICLES WITHOUT OEM KEYLESS ENTRY WILL BE (REV) IN THE HARNESS FROM THE DRIVERS DOOR.
Power Unlock     PINK/GREEN     (-)     IN GRAY PLUG TO RIGHT OF STEERING COLUMN VEHICLES WITHOUT OEM KEYLESS ENTRY WILL BE (REV) IN THE HARNESS FROM THE DRIVERS DOOR.
Driver Door Motor 1     PINK/BLACK     (+)     IN HARNESS IN DRIVERS KICKPANEL
Driver Door Motor 2     ORANGE / BLACK     (+)     IN HARNESS IN DRIVERS KICKPANEL
Factory Alarm Disarm     GREEN/ VIOLET     (-)     ABOVE GAS PEDAL
Parking Brake     LIGHT GREEN/ RED     (-)     PARKING BRAKE SWITCH
Rearview Mirror Accessory     LIGHT BLUE/PINK     (+)     IN REARVIEW MIRROR HARNESS     PIN #1
Rearview Mirror Ground     BLACK     (-)     IN REARVIEW MIRROR HARNESS     PIN #2
Low Speed Wipers     GRAY/LIGHT BLUE     (-)     IGNITION SWITCH HARNESS
OE Anti-Theft Information
     Description
Anti Theft Name     FORD PATS® OR SECURILOCK® VEHICLE IMMOBILIZER
Anti Theft Type     THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Engine Wiring
Tach     WHITE/ PINK     (-)     AT MODULE ON FIREWALL - PIN #19
Speed Sense     GRAY/BLACK     (AC)     AT PCM MODULE ON DRIVER SIDE FIREWALL     GRAY PLUG PIN #58
Neutral Safety     RED / LIGHT BLUE     (-)     IGNITION SWITCH HARNESS
marylegz
Posted: December 05, 2016 at 11:23 AM / IP Logged Link to Post Post Reply Quote marylegz
i am an idiot wrote:
Power Connections
Triggers
Lighting
Integration
     Description
Engine Wiring
Thanks! Ya, I figured the 2002 engine harness would at least be different, wasn't 100% sure on the interior stuff. Figured 2004 would be better to follow, but trying to dot my i's and cross my t's.
