2012 Dodge Durango Alarm Wiring
mmbltcsw12
Posted: December 23, 2016 at 8:04 AM / IP Logged Link to Post Post Reply Quote mmbltcsw12
I'm looking for alarm wiring or at least 12V constant and ignition for a 12 Durango. Thank you in advance!
wirewise
Moderator - Posts: 489
Posted: January 08, 2017 at 7:08 AM / IP Logged Link to Post Post Reply Quote wirewise
DURANGO      2011-2013
KEY      T-HARNESS      IMMOBILIZER
N/A      N/A      MULTIPLEX IGNITION/ANTI-THEFT SYSTEM, SEE NOTE #1
PART      COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      RED (+)      @ BATTERY or TIP Module, SEE NOTE #2
STARTER      NOT USED FOR REMOTE STARTING!
STARTER 2      N/A
IGNITION 1      PINK/WHITE (+) for IGNITION SENSE ONLY!!      @ WIRELESS IGNITION NODE, BLACK 12-PIN PLUG, PIN 3, at IGNITION SWITCH
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY /HEATER BLOWER 1      N/A
ACCESSORY /HEATER BLOWER 2      N/A
KEYSENSE      N/A
PARKING LIGHTS ( - )      WHITE/ LT. GREEN (-) THRU a 1130 Ohm Resistor, use Relay to isolate Switch      @ HEADLIGHT SWITCH, BLACK 6-PIN PLUG, PIN 3
PARKING LIGHTS ( + )      WHITE/ BROWN (+) (L) & WHITE/ ORANGE (+) (R)      IN DRIVERS KICK, HARNESS to REAR of VEHICLE
POWER LOCK      PURPLE / LT.GREEN (-) THRU a 330 Ohm Resistor LOCKS      @ PASSENGER DOOR MODULE, BLACK 10-PIN PLUG, PIN 4
POWER UNLOCK      Smae wire, (-) THRU a 100 Ohm Resistor will UNLOCK
LOCK MOTOR WIRE      TAN/WHITE (5-WIRE TYPE)      IN DRIVERS KICK, at HARNESS to DOOR
DOOR TRIGGER      PURPLE (-)      IN DRIVERS KICK, at HARNESS to DOOR
DOMELIGHT SUPERVISION      YELLOW/WHITE (+)      IN DRIVERS KICK, HARNESS to REAR of VEHICLE
TRUNK RELEASE      PURPLE / TAN (-) THRU a 4700 Ohm Resistor      @ OVERHEAD CONSOL, 16-PIN PLUG, PIN 15
SLIDING POWER DOOR      N/A
HORN      GRAY / YELLOW(+)(HORN 1) and GRAY/LT.BLUE (+) (HORN 2)      @ HORNS or TIP Module, GREEN 26-PIN PLUG(C3), PINS 18 and 24, SEE NOTE #2
TACH      Any wire NOT BROWN / WHITE (AC)      @ Any FUEL-INJECTOR
WAIT TO START LIGHT      N/A
BRAKE      WHITE/ DK.GREEN (+)      @ BRAKE PEDAL SWITCH
FACTORY ALARM DISARM      N/A
ANTI-THEFT      MULTIPLEX IGNITION/ANTI-THEFT SYSTEM
NOTES
NOTE #1: VEHICLE IS EQUIPPED WITH A TRANSPONDER/ MULTIPLEX IGNITION ANTI-THEFT SYSTEM AND REQUIRES AN INTERFACE MODULE PART #DBALL2 or XK09 FOR REMOTE STARTING.
#2: The TIP Module is located in the ENGINE COMPARTMENT, on the PASSENGER Fender.
~wirewise~
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
