2010 Nissan Titan Alarm/Remote Start Wiring
omng464
Member - Posts: 9
Posted: February 02, 2017 at 9:23 AM / IP Logged
I am looking for the wiring for a 2010 titan. I looked on the list and it shows 2008 as the newest. Thank for the awesome site and forums!!!!!
wirewise
Moderator - Posts: 489
Posted: February 02, 2017 at 9:29 AM / IP Logged
2007 through 2015 are the same.
TITAN      2007-2015
KEY      T-HARNESS      IMMOBILIZER
N/A      N/A      NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #1
PART      COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      GREEN (+)      @ IGNITION SWITCH, (WHITE, 6-PIN LUG), PIN 3
STARTER      BROWN (+)      @ IGNITION SWITCH, (WHITE, 6-PIN LUG), PIN 2
STARTER 2      LT. GREEN (+)      @ IGNITION SWITCH, (WHITE, 6-PIN LUG), PIN 6
IGNITION 1      BLACK/ RED (+)      @ IGNITION SWITCH, (WHITE, 6-PIN LUG), PIN 1
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY /HEATER BLOWER 1      RED (+)      @ IGNITION SWITCH, (WHITE, 6-PIN LUG), PIN 4
ACCESSORY /HEATER BLOWER 2      PURPLE (+)      @ IGNITION SWITCH, (WHITE, 6-PIN LUG), PIN 5
KEYSENSE      N/A
PARKING LIGHTS ( - )      N/A
PARKING LIGHTS ( + )      RED / BLUE (+)      @ ELECTRIC BRAKE Pre-wiring Harness, (WHITE, 6-PIN PLUG), PIN 4, NOTE #5
POWER LOCK      BLUE (TYPE B), NOTE #3      @ POWER WINDOW Main Switch, (WHITE, 16-PIN PLUG), PIN 6 or 4
POWER UNLOCK      RED (TYPE B), Requires Double Pulse, NOTE #4      @ POWER WINDOW Main Switch, (WHITE, 16-PIN PLUG), PIN 7 or 6
LOCK MOTOR WIRE      PURPLE (5-wire type)      in DRIVERS KICK PANEL or BCM, (BLACK, 15-PIN PLUG), PIN 10, NOTE #2
DOOR TRIGGER      LT. BLUE (-)      in DRIVERS KICK PANEL or BCM, (BLACK, 15-PIN PLUG), PIN 10, NOTE #2
DOMELIGHT SUPERVISION      BLUE (-)      @ DRIVERS KICK A Pillar or BCM, (BLACK, 15-PIN PLUG), PIN 8, NOTE #2
TRUNK RELEASE      N/A
SLIDING POWER DOOR      N/A
HORN      RED / WHITE (-)      @ HORN Switch, (GRAY, 8-PIN PLUG), PIN 2, Under Steering Column cover
TACH      Any wire NOT WHITE (AC)      @ Any FUEL-INJECTOR
WAIT TO START LIGHT      N/A
BRAKE      RED / GREEN to RED / BLACK (+)      @ BRAKE PEDAL Switch or in PASSENGER KICK PANEL, Harness to REAR of vehicle
FACTORY ALARM DISARM      Use UNLOCK wire
ANTI-THEFT      NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #1
NOTES
NOTE #1: This vehicle is Equipped with NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, for REMOTE STARTING ONLY you will need the Part #791 BYPASS Module or B-SERIES REMOTE STARTER and an Extra Ignition key. (Requires extra key for Operation)
Part # XK09 for REMOTE STARTING ONLY, requires 1 key for programming, NO key required for Operation.
Part # DBALL2 for REMOTE START/KEYLESS Entry, requires 1 key for programming and NO Key for Operation.
TO ORDER CALL TECH SUPPORT 800 878 8007 9am to 5pm M-F. NOTE #2: the BCM (Body Control Module) is located under the Drivers Dash and to the RIGHT of the Steering Column.
NOTE #3: TEST this wire while Turning the KEY in the Drivers Door. This wire will also ARM the FACTORY ALARM.
NOTE #4: TEST this wire while Turning the KEY in the Drivers Door. This wire will also DISARM the FACTORY ALARM.
NOTE #5: the ELECTRIC BRAKE Pre-wiring Harness is located Under the DRIVERS DASH, and to the RIGHT of the STEERING COLUMN.
~wirewise~ Verify all wiring with your meter before making any connections!
Tuesday, October 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
