2010 toyota tundra radio
anthonyc...
Posted: May 21, 2017 at 4:14 PM / IP Logged Link to Post Post Reply Quote anthonyc...
To whom it may concern,
I had to replace my evaporator, I did what I had to. Remove the dash. Lets start from the beginning, I disconnected the negative battery cable, removed the dash skin, the mounting bar, and the duct work. Replaced everything, the A/C works beautiful. Everything works but the radio, the clock, and ambient temperature readout.   I checked all my fuses, removed the skin again to double check my connections, and checked for pushed pins. I'm stumped! The next thing I need to do is trace the wiring.   Has anyone ever experienced the radio not working after a dash removal? Did I do wrong by only disconnecting the negative battery cable, should I have disconnected the positive cable as well?
If anyone out there can help me out I would really appreciate it.
Thanking you in advance,
Anthony C
"take it easy while you're going fast!"
