2015 Hyundai Sonata Remote Start
doubtedthreads
Posted: April 10, 2019 at 8:32 AM / IP Logged Link to Post Post Reply Quote doubtedthreads
I am in need of the wiring diagram for a 2015 Hyundai Sonata. I need to install a remote start and need to know what and how to buy/install as the bypass and where to hook everything. I am finding a 2014 but I am afraid its not the same as the 2015.
I don't know what the kind of key it has is called. It has a remote with lock, unlock, and trunk on it. It has the key that flips out and is "inverted" type cut key (it is cut into the middle of the key instead of outside edges of the key) So it has a key start not push button.
Any help will be greatly appreciated as I do not want to mess up the electrical system in the car. I tried to give as much information as I could. I am much better with lawnmowers than cars! Thanks.
geepherder
Platinum - Posts: 3,668
Posted: April 11, 2019 at 4:04 AM / IP Logged Link to Post Post Reply Quote geepherder
You could check the bypass websites for some wiring information. Fortin actually has some photos of the connectors, but they should all have certain pinouts of your main wires. You can look them up at https://fortin.ca/, http://www.idatalink.com/, https://old.directechs.com/. There's an example from each of the main three interface companies listed below:
https://cdn02.fortin.ca/download/22981/evo-all_ig_reg_bi_hyu-sonata_2015-2016_key_b_22981.pdf
http://images.idatalink.com/corporate/Content/Manuals/DL-HK5/ADS-AL(DL)-HK5-EN_20190108.pdf
https://directechs.blob.core.windows.net/ddt/933-HK4-2.06.193_2015-Hyundai-Sonata_IG_EN_20190121.pdf
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
