2016 Hyundai Elantra GT Alarm/Remote Start Wiring
bn880
Member - Posts: 28
Posted: June 11, 2019 at 3:44 PM / IP Logged Link to Post Post Reply Quote bn880
Hello, I am wondering if someone could provide the alarm and remote start wiring for a 2016 Elantra GT? This vehicle is a Canadian model which I believe has an immobilizer. I noticed the info for 2011 to 2015 posted, but it probably isn't 1:1 for 2016? https://www.the12volt.com/installbay/forum_posts.asp?tid=139756
geepherder
Platinum - Posts: 3,668
Posted: June 11, 2019 at 4:03 PM / IP Logged Link to Post Post Reply Quote geepherder
According to Bulldog, the 2011-2016 is the same:
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.aspx
http://diagrams.marktoonen.nl/printlist.aspx?MakeID=21&ModelID=20358
bn880
Member - Posts: 28
Posted: June 11, 2019 at 4:22 PM / IP Logged Link to Post Post Reply Quote bn880
Thanks for that, I will see how that pans out then. :)
bn880
Member - Posts: 28
Posted: June 26, 2019 at 9:14 AM / IP Logged Link to Post Post Reply Quote bn880
Hi, just reporting back.   The install went pretty well but there were some differences.
- There is no green tach wire at the right kick panel on the 2016 GT, this I got from the camshaft position sensor , middle green wire on 3 pin plug located at driver side top of engine.
- Dome light supervision wire is a yellow wire in the Drivers front Pillar (24 pin plug)
- For immobilizer , EMS Data/comms wire is Blue Black pin 12 of 58 pin connector at driver's kick panel
- if you want to do AUX stuff, pulsing +12V to Green/Orange (pin 12), Brown/Orange (pin 13) pins at back of Climate control unit 16 pin white connector will turn on heated seats.
- lock, unlock arm/disarm as per https://www.the12volt.com/installbay/forum_posts.asp?tid=139756 worked well; did not work well when connecting according to other diagrams provided by bulldog/Wire color etc. (wouldn't unlock doors)
