2003 Dodge Neon SXT ECU C4 Connector
ichitu
Posted: August 19, 2019 at 9:10 PM / IP Logged Link to Post Post Reply Quote ichitu
My 03 Neon has a transmission issue which appears to be electrical in nature.   If I clean and re-seat the green connector on the ECU (C4), it goes away for a short time. The issue is that the transmission drops out of gear (as into Neutral) especially when making right turns but will go back into gear when the engine is revved. Is there a pin-out or diagram for that connector anywhere?
Thanks!
Ween
Platinum - Posts: 1,368
Posted: August 19, 2019 at 10:02 PM / IP Logged Link to Post Post Reply Quote Ween
http://connectors.dcctools.com/home.htm
