2016 Honda CR-V Backup Camera Video Wires
toddwino
Posted: October 06, 2019 at 10:48 AM / IP Logged Link to Post Post Reply Quote toddwino
I installed a Kenwood aftermarket stereo into my 2016 Honda CRV, and everything works great.    EXCEPT - when I shift into reverse, there is no video feed into the Kenwood. The original video feed into the upper OEM camera is still there. When I shift into reverse, the Kenwood goes to the camera, but since there is no feed, it seems like I need to find the video feed wire, tap into it and connect it to an RCA jack. Then the RCA jack can go into the back of the Kenwood. Any help which wire(s) into the upper OEM unit (BIM?) unit are the video feeds?    Thanks in advance
Toddwino in NJ
eguru
Copper - Posts: 340
Posted: October 06, 2019 at 3:02 PM / IP Logged Link to Post Post Reply Quote eguru
No idea, but look for a wire that has a shield around it. The shield will be connected to ground at the camera end (and also at the "display").
toddwino
Posted: October 08, 2019 at 1:42 PM / IP Logged Link to Post Post Reply Quote toddwino
So I found the two leads off the MID connector - position 19(red wire) is video+ and position 3(white wire) is video-. Now the problem - The camera feed gives just a black screen, but it is getting a signal. Any suggestions?
