1968 Mercury Cougar, Remote Start Wiring
pvgreen21
Posted: December 14, 2019 at 3:41 PM / IP Logged Link to Post Post Reply Quote pvgreen21
I want to install a compustar remote start alarm on my 1968 Mercury Cougar base model. I can't find an alarm wiring diagram anywhere for this car. Please help
Patrick v. Green
Platinum - Posts: 13,723
Posted: December 14, 2019 at 8:44 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Do you have a volt meter? There will be less than 5 wires at the ignition switch. First find the constant wire. It will probably be the largest wire. There will be a smaller wire that has power when ignition switch is in the on position and the accessory position (If there is an acc position) This will be the accessory wire. Another large wire will have 12 volts when the key is in the on position and will still have power when the key is turned to the start position. This is the ignition wire. Probably the only remaining wire will be the start wire. It will only have voltage on it when turned to the start position.
Ween
Platinum - Posts: 1,368
Posted: December 15, 2019 at 12:20 PM / IP Logged Link to Post Post Reply Quote Ween
Yellow...Battery, Black/Green...Accessory, Red/Green...Ignition, Red/Blue...Start
mgoetz74
Silver - Posts: 424
Posted: December 16, 2019 at 11:27 AM / IP Logged Link to Post Post Reply Quote mgoetz74
ok ill ask...carb or fuel injected?
pvgreen21
Posted: December 20, 2019 at 10:37 PM / IP Logged Link to Post Post Reply Quote pvgreen21
Carburetor with electric choke
Patrick v. Green
pvgreen21
Posted: December 21, 2019 at 6:29 PM / IP Logged Link to Post Post Reply Quote pvgreen21
That model has no tach but the remote start has a tach input. How do I wire that
Patrick v. Green
Ween
Posted: December 21, 2019 at 6:59 PM / IP Logged Link to Post Post Reply Quote Ween
The ignition coil has a positive (+) terminal as well as a negative (-) terminal. Connect to the negative.
Friday, October 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
