2012 Nissan Sentra, Door Open Indicator Stays On
njsdesipunk
Posted: December 18, 2019 at 9:14 AM / IP Logged Link to Post Post Reply Quote njsdesipunk
while installing remote start in my 12 sentra, I accidently broke dooe unlock wire on BCM connector.I connected a cable using another cable but Now my door open sign on cluster stays on.
Can someone help me repair this issue?
geepherder
Platinum - Posts: 3,668
Posted: December 21, 2019 at 5:33 AM / IP Logged Link to Post Post Reply Quote geepherder
The first thing I would do is disconnect the door jamb switches one at a time to see if the door open indicator light goes out.
This will tell you if there's an issue with one of the switches that may coincidentally be causing the issue.
eguru
Copper - Posts: 340
Posted: December 21, 2019 at 7:47 AM / IP Logged Link to Post Post Reply Quote eguru
I don't know how the Sentra door switches work but on many vehicles the door switch is closed when the door is closed.
Disconnecting the individual door jamb switches won't help identify the cause if that is how Sentra implements the door open check.
If the BCM connector was removed to repair the broken wire, perhaps it is not latched properly or an individual contact has been pushed back into the mounting wafer.
geepherder
Posted: December 21, 2019 at 9:05 PM / IP Logged Link to Post Post Reply Quote geepherder
As eguru points out, it is important to know what type switches your car uses. Your door switches should show a ground when the door is open.
http://www.bbbind.com/tsb-wiring-diagrams-database-results/?type=WD&years=2012&make=65&makeDesc=Nissan&model=832&modelDesc=Sentra&system=17&systemDesc=Warning%20Systems&subsystem=197&subsystemDesc=Warning%20Lamps&docid=8197119
Be sure to also check the trunk switch (it may be built into the latch assembly). If your testing doesn't reveal a shorted switch, you can test the wires while the switches are disconnected. The door switches only have one wire. They should not test as ground while disconnected. The trunk switch has two wires, one black and one white/green. White green should not be grounded while disconnected.
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
