2016 Land Rover Discovery Sport, Audio Wiring Diagram
hayesjl77
Posted: August 05, 2020 at 5:20 AM / IP Logged Link to Post Post Reply Quote hayesjl77
Hello!
I bought a used 2016 Land Rover Discovery Sport. Much to my surprise I've not been able to find anything definitive on wiring for the audio system. Land Rover seems to be a black hole dark end of space for information. Anything anyone has would be a great help. Looking to replace speakers and amps. Factory radio has so much integration into AC, seats etc probably not going to bother trying to replace the head unit.
Thank you in advance
tonanzith
Gold - Posts: 603
Posted: October 01, 2020 at 1:38 PM / IP Logged Link to Post Post Reply Quote tonanzith
here you go
Item     Wire Color     Polarity     Wire Location
Radio 12V     Yellow     +     Radio, black 16 pin plug, pin 13 or gray 14 pin plug, pin 1
Radio Ground     Black/Yellow     -     Radio, black 16 pin plug, pin 11 or gray 14 pin plug, pin 8
Radio Ignition     (MS CAN or MOST)
Power Antenna     Yellow/Orange     +     Radio, blue 12 pin plug, pin 4 or gray 14 pin plug, pin 2
Left Front Speaker (+/-)     Green/Orange - Gray/Orange     +,-     Radio, black 16 pin plug, pins 3 - 7
Right Front Speaker (+/-)     Violet/Orange - Yellow/Orange     +,-     Radio, black 16 pin plug, pins 2 - 6
Left Rear Speaker (+/-)     White/Green - Brown/Yellow     +,-     Radio, black 16 pin plug, pins 4 - 8
Right Rear Speaker (+/-)     Brown/White - Brown/Blue     +,-     Radio, black 16 pin plug, pins 1 - 5
Left Front Speaker - With Amp     White - White/Brown     +,-     Amplifier under driver seat, black 16 pin plug, pins 3 - 11 or gray 16 pin plug, pins 2 - 10
Right Front Speaker - With Amp     White/Violet - White/Orange     +,-     Amplifier under driver seat, black 16 pin plug, pins 6 - 14 or gray 16 pin plug, pins 4 - 12
Left Front Tweeter - With Amp     Green/Blue - Gray/Blue (midrange/tweeter)     +,-     Amplifier under driver seat, black 16 pin plug, pins 2 - 10 or gray 16 pin plug, pins 1 - 9
Right Front Tweeter - With Amp     Violet/Gray - Yellow/Gray (midrange/tweeter)     +,-     Amplifier under driver seat, black 16 pin plug, pins 5 - 13 or gray 16 pin plug, pins 3 - 11
Left Rear Speaker - With Amp     White/Green - Brown/Yellow     +,-     Amplifier under driver seat, black 16 pin plug, pins 4 - 12 or gray 16 pin plug, pins 5 - 13
Right Rear Speaker - With Amp     Brown/White - Brown/Blue     +,-     Amplifier under driver seat, black 16 pin plug, pins 7 - 15 or gray 16 pin plug, pins 7 - 15
Subwoofer - With Amp     Green/Violet - Gray (coil 1); Violet - Yellow (coil 2)     +,-     Amplifier under driver seat, brown 8 pin plug, pins 1 - 5; black 16 pin plug, pins 8 - 16 or gray 16 pin plug, pins 6 - 14; 8 - 16
Aux. Audio Input Left (+/-)     Blue - White/Green or Blue - Black     +,-     Radio, green 12 pin plug, pins 10 - 4 or gray 14 pin plug, pins 5 - 7
Aux. Audio Input Right (+/-)     Blue/Green - White/Green or Green - Black     +,-     Radio, green 12 pin plug, pins 3 - 4 or gray 14 pin plug, pins 6 - 7
Gary Sather
