2017 Subaru Forester PTS Door Lock Wiring
craiga
Posted: September 22, 2020 at 3:58 PM / IP Logged Link to Post Post Reply Quote craiga
I'm looking for door lock wiring for a 2017 Subaru Forester XT with PTS for a project I'm working on. Any help or info is appreciated!
Thanks!
-Craig
tonanzith
Gold - Posts: 603
Posted: October 01, 2020 at 1:09 PM / IP Logged Link to Post Post Reply Quote tonanzith
here you go:
2017 Subaru Forester (Smart Key) - North America
Item     Wire Color     Polarity     Wire Location
12 Volts     Red (50A)     +     Dash Fuse Box, rear, brown 9 pin plug, pin 6
Ground     (chassis ground)
Starter Kill     White/Red     +     Relay Holder behind dash fuse box, black 44 pin plug, pin 1
Starter     Brown     +     Keyless Access Module right of BIU, white 18 pin plug, pin 7
Ignition     Violet     +     Keyless Access Module right of BIU, white 30 pin plug, pin 6
Second Ignition     Tan     +     Keyless Access Module right of BIU, white 18 pin plug, pin 9
Accessory     Violet     +     Keyless Access Module right of BIU, white 30 pin plug, pin 4
PTS 1     Green     -     Keyless Access Module right of BIU, white 30 pin plug, pin 30
PTS 2     White     -     Keyless Access Module right of BIU, white 30 pin plug, pin 28
CAN Bus High     Red     Data     OBD-Data Link Connector, white 16 pin plug, pin 6
CAN Bus Low     Blue     Data     OBD-Data Link Connector, white 16 pin plug, pin 14
CAN Bus High 2     White     Data     Keyless Access Module right of BIU, white 30 pin plug, pin 14
CAN Bus Low 2     Red     Data     Keyless Access Module right of BIU, white 30 pin plug, pin 15
CAN Bus High 3     Red     Data     BIU behind dash fuse box, white 35 pin plug (B), pin 20
CAN Bus Low 3     Blue     Data     BIU behind dash fuse box, white 35 pin plug (B), pin 28
OBD 12 Volts     Green (7.5A)     +     OBD-Data Link Connector, white 16 pin plug, pin 16
OBD Ground     Black/Green or Black     -     OBD-Data Link Connector, white 16 pin plug, pin 4
OBD Ignition     Pink     +     OBD-Data Link Connector, white 16 pin plug, pin 8
OBD Connector     White          Under Driver Dash, Behind Dash Fuse Box
IMMO Data     White/Blue (non-turbo)     Data     ECM behind glove box, gray 65 pin plug, pin 38
IMMO Data 2     Green/Black (turbo)     Data     ECM on passenger fender, black 48 pin plug, pin 43
Security Light     Brown/Red     -     BIU behind dash fuse box, white 31 pin plug (D), pin 26
Keyless Data     White     Data     Keyless Access Module right of BIU, white 28 pin plug, pin 17
Power Lock     lt. blue     -     BIU behind dash fuse box, white 35 pin plug (C), pin 9
Power Unlock     blue/black     -     BIU behind dash fuse box, white 35 pin plug (C), pin 20
Power Lock2     lt. blue (alternate location)     -     driver kick, white 28 pin plug, pin 20
Power Unlock2     blue/black (alternate location)     -     driver kick, white 28 pin plug, pin 21
Lock Motor     white     reverse     driver kick, white 28 pin plug, pin 17
Driver Unlock Motor     red/green     reverse     driver kick, white 28 pin plug, pin 18
Passenger Unlock Motor     yellow to lt. green     reverse     driver kick, white 19 pin plug, pin 7
Factory Alarm Arm     (arms on lock with door open)
Factory Alarm Disarm     (proximity key and push button)
Parking Lights     lt. blue     +     dash fuse box, white 20 pin plug, pin 12
Parking Lights -     lt. green     -     BIU behind dash fuse box, white 35 pin plug (B), pin 17
Parking Lights NEG 2     lt. green (alternate location)     -     Headlight Switch, white 20 pin plug, pin 18
Hazards     pink     -     BIU behind dash fuse box, white 31 pin plug (D), pin 18
Turn Signal (Left)     white/red     +     dash fuse box, white 20 pin plug, pin 20
Turn Signal (Right)     green     +     dash fuse box, white 20 pin plug, pin 3
Headlight     white/green     -     BIU behind dash fuse box, white 35 pin plug (B), pin 34
AutoLights     pink     cut     BIU behind dash fuse box, white 35 pin plug (B), pin 16
Reverse Light     brown/yellow     +     driver kick, white 14 pin plug, pin 14
Left Front Door Trigger     blue to white     -     driver kick, white 19 pin plug, pin 10
Left Front Door Trigger 2     white (alternate location)     -     BIU behind dash fuse box, white 35 pin plug (C), pin 14
Right Front Door Trigger     brown/black     -     BIU behind dash fuse box, white 35 pin plug (C), pin 13
Left Rear Door Trigger     green     -     BIU behind dash fuse box, white 35 pin plug (C), pin 24
Right Rear Door Trigger     tan     -     BIU behind dash fuse box, white 35 pin plug (C), pin 25
Dome Light     brown     -     BIU behind dash fuse box, white 35 pin plug (C), pin 4
Trunk/Hatch Pin     brown     -     BIU behind dash fuse box, white 35 pin plug (C), pin 33
Hood Pin     green (with remote start)     -     Remote Start Module Connector above brake pedal, white 8 pin plug, pin 5
Power Liftgate     brown     +     power liftgate switch, white 6 pin plug, pin 1
Trunk/Hatch Release     blue (rear handle switch)     -     BIU behind dash fuse box, white 35 pin plug (C), pin 10
Trunk Release Motor     black (w/o power liftgate)     reverse     BIU behind dash fuse box, white 31 pin plug (D), pin 7
Tachometer     red     ac     Keyless Access Module right of BIU, white 18 pin plug, pin 17
Fuel Pump     red/black     +     passenger kick, white 14 pin plug, pin 4
Rear Defroster     tan     - latched     BIU behind dash fuse box, white 34 pin plug (A), pin 26
Mirror Defroster     (same as rear defroster)
Wiper Deicer     blue     - latched     BIU behind dash fuse box, white 31 pin plug (D), pin 9
Left Front Heated Seat     red (LO)     reverse     left seat heater switch, white 6 pin plug, pin 5
Right Front Heated Seat     blue (LO)     reverse     right seat heater switch, brown 6 pin plug, pin 5
Speed Sense     pink/green     ac     radio, white 28 pin plug, pin 17
Brake Wire     lt. green     +     Keyless Access Module right of BIU, white 18 pin plug, pin 18
Parking Brake     gray     -     dash fuse box, white 20 pin plug, pin 13
Horn Trigger     blue     -     BIU behind dash fuse box, white 34 pin plug (A), pin 24
Horn Trigger 2     blue (alternate location)     -     horn switch, white 14 pin plug, pin 9
Wipers     red/blue (LO); black/blue (HI)     +     wiper switch, white 10 pin plug, pin 3 (LO); pin 4 (HI)
Wipers Protection     green/black (ignition)     cut     wiper switch, white 10 pin plug, pin 2
Left Front Window (Up/Down)     blue/red - lt. green/red     A     power window main switch, white 3 pin plug, pins 3 - 1
Right Front Window (Up/Down)     red - red/yellow (w/o auto-reverse); blue/red - lt. green/red (with auto-reverse)     A     driver kick, white 28 pin plug, pins 5 - 6 (w/o auto-reverse); passenger window switch, white 12 pin plug, pins 2 - 3 (with auto-reverse)
Left Rear Window (Up/Down)     green/red - black/yellow     A     driver kick, white 28 pin plug, pins 9 - 10
Right Rear Window (Up/Down)     blue - blue/yellow     A     driver kick, white 28 pin plug, pins 3 - 4
Sun Roof (Open/Close)     white - blue (function with ignition on only)     +     sunroof switch, white 5 pin plug, pins 1 - 4
Memory Seat 1     red     -     driver kick, white 28 pin plug, pin 22
Memory Seat 2     green/white     -     driver kick, white 28 pin plug, pin 28
Radio 12V     blue/red     +     radio, white 10 pin plug, pin 4
Radio Ground     black/blue     -     radio, white 10 pin plug, pin 7
Radio Ignition     yellow/red     +     radio, white 10 pin plug, pin 3
Radio Illumination     violet (parking lights); white (dimmer)     +,-     radio, white 10 pin plug, pin 10 (parking lights); white 6 pin plug, pin 5 (dimmer)
Power Antenna     yellow     +     radio, white 10 pin plug, pin 8
Left Front Speaker (+/-)     red - white or black - green     +,-     radio, white 10 pin plug, pins 2 - 6
Right Front Speaker (+/-)     brown - green or red - white     +,-     radio, white 10 pin plug, pins 1 - 5
Left Rear Speaker (+/-)     white - red or black - white     +,-     radio, white 6 pin plug, pins 2 - 6
Right Rear Speaker (+/-)     green - red     +,-     radio, white 6 pin plug, pins 1 - 3
Left Front Speaker - With Amp     blue/white - green     +,-     amplifier under driver seat, white 10 pin plug, pins 10 - 4
Right Front Speaker - With Amp     blue - pink     +,-     amplifier under driver seat, white 10 pin plug, pins 3 - 9
Left Front Tweeter - With Amp     green/yellow - violet     +,-     amplifier under driver seat, white 10 pin plug, pins 2 - 6
Right Front Tweeter - With Amp     yellow - lt. green     +,-     amplifier under driver seat, white 10 pin plug, pins 8 - 7
Left Rear Speaker - With Amp     green - brown     +,-     amplifier under driver seat, white 12 pin plug, pins 12 - 5
Right Rear Speaker - With Amp     white/red - black/red     +,-     amplifier under driver seat, white 12 pin plug, pins 10 - 4
Left Rear Tweeter - With Amp     white/blue - black/blue     +,-     amplifier under driver seat, white 12 pin plug, pins 3 - 9
Right Rear Tweeter - With Amp     yellow - black     +,-     amplifier under driver seat, white 12 pin plug, pins 1 - 2
Aux. Audio Input Left (+/-)     white - (shield)     +,-     radio, white 28 pin plug, pins 28 - 27
Aux. Audio Input Right (+/-)     black - (shield)     +,-     radio, white 28 pin plug, pins 26 - 27
Rearview Camera Video     black - (shield)     +,-     radio, white 28 pin plug, pins 12 - 13 or white 5 pin plug, pins 3 - 4
Gary Sather
craiga
Posted: October 01, 2020 at 6:30 PM / IP Logged Link to Post Post Reply Quote craiga
Awesome - thanks!
-Craig
