2005 Cadillac STS, Factory Stereo Wiring Diagram
mileszach87
Posted: April 04, 2021 at 2:39 AM / IP Logged Link to Post Post Reply Quote mileszach87
I accidentally let the wiring pins come out of my harness and don't know where they go can somebody please help me it's a 2005 Cadillac STS with CD changer no navigation basically it does everything in this car so I really need it.
Zach
mgoetz74
Silver - Posts: 424
Posted: April 15, 2021 at 2:22 PM / IP Logged Link to Post Post Reply Quote mgoetz74
Radio 12V     red/white     +     radio, gray 16 pin plug, pins 1 and 9
Radio Ground     black/white     -     radio, gray 16 pin plug, pins 8 and 16
Radio Ignition     (low speed GMLAN)
Radio Illumination     yellow (dimmer)     +     radio, gray 16 pin plug, pin 7
Factory Amp Turn-on     (low speed GMLAN)
Power Antenna     pink     +     radio, black 16 pin plug, pin 5
Left Front Speaker (+/-)     tan - dk. green     +,-     radio, gray 16 pin plug, pins 2 and 10
Right Front Speaker (+/-)     dk. green/white - lt. green     +,-     radio, gray 16 pin plug, pins 3 and 11
Left Rear Speaker (+/-)     brown/white - brown     +,-     radio, black 16 pin plug, pins 3 and 11
Right Rear Speaker (+/-)     dk. blue - tan     +,-     radio, black 16 pin plug, pins 4 and 12
Center Channel (+/-)     dk. blue - orange     +,-     radio, brown 16 pin plug, pins 3 and 11
Subwoofer (+/-)     white - orange     +,-     radio, brown 16 pin plug, pins 4 and 11
Aux. Audio Input Left (+/-)     yellow - (shield)     +,-     radio, black 10 pin plug, pins 1 and 7
Aux. Audio Input Right (+/-)     white - (shield)     +,-     radio, black 10 pin plug, pins 2 and 7
RSE Video (+/-)     violet - (shield) (aux. video input)     +,-     radio, brown 16 pin plug, pins 14 and 13
RSE Audio Left (+/-)     lt. green/white - gray/black (satellite audio)     +,-     radio, black 16 pin plug, pins 1 and 9
RSE Audio Right (+/-)     lt. blue/white - gray/black (satellite audio)     +,-     radio, black 16 pin plug, pins 2 and 9
Satellite Radio 12 Volts     red/white     +     Digital Radio Receiver, black 16 pin plug, pin 16
Satellite Radio Ground     black     -     Digital Radio Receiver, black 16 pin plug, pin 9
Satellite Radio Ignition     (low speed GMLAN)
Satellite Radio Antenna     (coaxial cable)
Satellite Audio Left (+/-)     lt. green/white - gray/black     +,-     Digital Radio Receiver, blk 16 pin plg, pins 2, 10
Satellite Audio Right (+/-)     lt. blue/white - gray/black     +,-     Digital Radio Receiver, blk 16 pin plg, pins 3, 10
Platinum - Posts: 13,726
Posted: April 15, 2021 at 8:07 PM / IP Logged Link to Post Post Reply Quote i am an idiot
I doubt the plug has numbers on it. In order to figure out which end is 1 and 9 you will need a multimeter. Do you have one or at least have access to one?
