2005 Chevrolet Classic, Security Wiring Diagram
marcusjones24
Member - Posts: 7
Posted: April 11, 2021 at 11:30 PM / IP Logged Link to Post Post Reply Quote marcusjones24
I'm looking for an wiring diagram for an 2005 Chevy classic. The only diagram i can find are for the Chevy malibu. I'm not looking to remote start, but only car security. Any relays needed with this vehicle?
Marcus Jones
marcusjones24
Member - Posts: 7
Vehicle uses a regular key.
Marcus Jones
mgoetz74
Silver - Posts: 424
Posted: April 15, 2021 at 2:18 PM / IP Logged Link to Post Post Reply Quote mgoetz74
12 Volts     red (40A)     +     ignition harness
Second 12 Volts     red (30A)     +     ignition harness
Ground     (chassis ground)
Starter     yellow     +     ignition harness
Ignition     pink     +     ignition harness
J1850     violet     data     OBD-data link connector, black 16 pin plug, pin 2
Power Lock     white (close doors to lock with single pulse)     -     driver kick, door harness
Power Unlock     same as power lock     -1500 ohms
Lock Motor     gray     5 wire     driver kick, door harness
Driver Unlock Motor     tan     5 wire     driver kick, door harness
Passenger Unlock Motor     tan     5 wire     passenger kick, door harness
Parking Lights     brown     +     passenger kick, harness to rear
Parking Lights -     white     -     BCM below passenger dash
Headlight     dk. blue     -high curr     headlight switch
Left Front Door Trigger     lt. green/black     -     driver kick, door harness
Right Front Door Trigger     lt. blue     -     driver running board, harness under driver seat
Left Rear Door Trigger     same as right front door trigger
Right Rear Door Trigger     same as right front door trigger
Dome Light     white     -     underdash light
Trunk/Hatch Pin     orange/black     -     trunk light
Trunk/Hatch Release     black/white     -     release switch
Trunk Release Motor     black/white     +     driver kick, harness to rear
Tachometer     white     ac     ignition control module
Fuel Pump     gray     +     driver kick, harness to rear
Horn Trigger     black     -     steering column
looks like you will need a relay for teh lock/unlock since its the same wire with a resistor
marcusjones24
Member - Posts: 7
Posted: June 15, 2021 at 9:10 AM / IP Logged Link to Post Post Reply Quote marcusjones24
I have an 2005 chevrolet classic. I looked up the wiring diagram and I am trying to locate the horn wire, which the wiring diagram states it is a black (-) wire located in the steering column. I disassembled the cover from the column and looked under the dash but can't find the location of my horn wire. The parking lights wire is said to be a brown(+) wire in the passenger kick panel. There are 6 brown wires in the passenger kick panel. Could someone guide me in the direction to finding the horn and parking lights wires?
marcusjones24
Member - Posts: 7
Posted: June 18, 2021 at 9:11 PM / IP Logged Link to Post Post Reply Quote marcusjones24
What kind of relay do I need for the lock/unlock since they both use the same negative wire?
mgoetz74
Silver - Posts: 424
Posted: June 19, 2021 at 10:07 AM / IP Logged Link to Post Post Reply Quote mgoetz74
If you are not doing a viper you can still use the 451m and hook it up like-
small plug with green blue red-cut off harness and connect green to lock output of alarm blue to unlock output of alarm red to constant
larger wires blue/black with 1500 ohm resistor to cars lock/unlock wire
larger wires green/black to same wire with no resistor added
purple and purple black to ground and white/black brown/black not used
https://www.amazon.com/s?k=451m&ref=nb_sb_noss_1
marcusjones24
Member - Posts: 7
Posted: July 02, 2021 at 9:20 PM / IP Logged Link to Post Post Reply Quote marcusjones24
The 451m relay was not needed.
