2019 Nissan Titan, Remote Start/Keyless Entry Wiring
caraudioholic24
Member - Posts: 37
Posted: December 10, 2021 at 6:33 AM / IP Logged Link to Post Post Reply Quote caraudioholic24
Good Morning 12 Volt Fam.. I am in need of wiring info for 2019 Nissan Titan with a key and separate key fob for keyless. Really miss my Directech info at times like this. Thank you in advance.
mgoetz74
Silver - Posts: 424
Posted: December 10, 2021 at 9:32 AM / IP Logged Link to Post Post Reply Quote mgoetz74
not seeing a key version with the year/model you listed only PTS on the regular gas and diesel version of the truck
12 Volts     White (50A)     +     BCM right of steering column, white 15 pin plug, pin 11
Ground     (chassis ground)
Starter     White     -     BCM right of steering column, black 40 pin plug, pin 22
Ignition     Green     +     BCM right of steering column, black 40 pin plug, pin 27
Second Ignition     Pink     -     BCM right of steering column, black 40 pin plug, pin 30
Accessory     White     +     BCM right of steering column, black 40 pin plug, pin 26
Second Accessory     Blue     +     BCM right of steering column, black 24 pin plug, pin 9
PTS 1     Green     -     BCM right of steering column, green 40 pin plug, pin 1
CAN Bus High     Blue     Data     BCM right of steering column, black 40 pin plug, pin 20
CAN Bus Low     Pink     Data     BCM right of steering column, black 40 pin plug, pin 19
CAN Bus High 2     Blue (DIAG CAN)     Data     OBD-Data Link Connector, white 16 pin plug, pin 6
CAN Bus Low 2     Pink (DIAG CAN)     Data     OBD-Data Link Connector, white 16 pin plug, pin 14
OBD 12 Volts     Yellow (10A)     +     OBD-Data Link Connector, white 16 pin plug, pin 16
OBD Ground     Black     -     OBD-Data Link Connector, white 16 pin plug, pin 4
OBD Ignition     Green/Red     +     OBD-Data Link Connector, white 16 pin plug, pin 8
OBD Connector     White          Under Driver Dash, Below Steering Column
IMMO Antenna     (NATS antenna is on the push button ignition switch)
Security Light     Violet     -     BCM right of steering column, green 40 pin plug, pin 18     Directwire
Power Lock     (use factory alarm arm)
Power Unlock     (use factory alarm disarm)
Lock Motor     Orange     Reverse     BCM right of steering column, white 15 pin plug, pin 7
Driver Unlock Motor     Violet     Reverse     BCM right of steering column, white 15 pin plug, pin 9
Passenger Unlock Motor     Lt. Green     Reverse     BCM right of steering column, white 15 pin plug, pin 2
Factory Alarm Arm     White/Red (key lock)     -     Power Window Main Switch, white 16 pin plug, pin 3
Factory Alarm Disarm     Black/White (key unlock)     Double -     Power Window Main Switch, white 16 pin plug, pin 9
Parking Lights     Blue     +     Electric Brake Pre-Wiring above parking brake, white 6 pin plug, pin 4
Hazards     White/Black     -     BCM right of steering column, green 40 pin plug, pin 36
Turn Signal (Left)     Green/Black (LF); Green/Black (LR)     +     BCM right of steering column, black 24 pin plug, pin 13 (LF); gray 24 pin plug, pin 23 (LR)
Turn Signal (Right)     Green/Yellow (RF); Orange (RR)     +     BCM right of steering column, black 24 pin plug, pin 1 (RF); gray 24 pin plug, pin 12 (RR)
Headlight     Blue (L LO); Red/Yellow (R LO); Green (L HI); Blue/White (R HI)     +     Underhood Fuse Box, white 16 pin plug, pins 5, 6, 4, 3
Reverse Light     Green/White     +     Passenger Kick, white 100 pin plug, pin 15
Left Front Door Trigger     Tan     -     BCM right of steering column, gray 24 pin plug, pin 16
Right Front Door Trigger     Green     -     BCM right of steering column, gray 24 pin plug, pin 14
Left Rear Door Trigger     White     -     BCM right of steering column, gray 24 pin plug, pin 2
Right Rear Door Trigger     Red     -     BCM right of steering column, gray 24 pin plug, pin 13
Dome Light     Blue     -     BCM right of steering column, white 15 pin plug, pin 8
Hood Pin     Yellow     -     Underhood Fuse Box, white 12 pin plug, pin 10
Tachometer     White/Violet (diesel); Pink (gas)     ac     Camshaft Position Sensor, engine passenger side front, black 3 pin plug, pin 3
Wait to Start     (program wait to start timer)
Fuel Pump     Brown (diesel); Black/Yellow (gas)     +     Underhood Fuse Box, black 6 pin plug, pin 2
Rear Defroster     Orange     - Latched     BCM right of steering column, black 40 pin plug, pin 21
Mirror Defroster     (same as rear defroster)
Left Front Heated Seat     Tan (without climate controlled seat)     Reverse     Left Front Heated Seat Switch, white 6 pin plug, pin 5
Right Front Heated Seat     White (without climate controlled seat)     Reverse     Right Front Heated Seat Switch, brown 6 pin plug, pin 5
Left Front Heated Seat 2     Pink (with climate controlled seat)     + Resistor     Left Climate Controlled Seat Switch, white 10 pin plug, pin 1
Right Front Heated Seat 2     Blue (with climate controlled seat)     + Resistor     Right Climate Controlled Seat Switch, brown 8 pin plug, pin 1
Speed Sense     Green     8-Pulse     Radio, white 20 pin plug, pin 18
Brake Wire     Red/Green     +     BCM right of steering column, green 40 pin plug, pin 27
Brake Wire 2     Red/Green (alternate location)     +     Electric Brake Pre-Wiring above parking brake, white 6 pin plug, pin 2
Parking Brake     Green     -     Driver Kick, white 24 pin plug, pin 13
Horn Trigger     Red/White     -     Horn Switch-Clock Spring, gray 8 pin plug, pin 5 or yellow 6 pin plug, pin 1
Wipers     Brown (LO); Yellow (HI)     +     Underhood Fuse Box, brown 12 pin plug, pins 11, 5
Left Front Window (Up/Down)     White - Red     A     Power Window Main Switch, white 3 pin plug, pins 3 - 1
Right Front Window (Up/Down)     Green - Blue     A     Passenger Power Window Switch, white 12 pin plug, pins 11 - 12
Left Rear Window (Up/Down)     Yellow - Blue     A     Driver Kick, door harness, white 16 pin plug, pins 13 - 12
Right Rear Window (Up/Down)     Violet - Lt. Blue     A     Driver Kick, door harness, white 16 pin plug, pins 15 - 14
Rear Sliding Window Open-Close     Blue/White - Green (function with ignition on only)     -     Passenger Kick, white 32 pin plug, pins 11 - 10
Memory Seat 1     Violet     -     Driver Kick, door harness, white 40 pin plug, pin 5
Memory Seat 2     Lt. Green     -     Driver Kick, door harness, white 40 pin plug, pin 26
Radio 12V     White     +     Radio, white 20 pin plug, pin 19
Radio Ground     Black     -     Radio, white 20 pin plug, pin 20
Radio Ignition     Red     +     Radio, white 20 pin plug, pin 7
Radio Illumination     Blue     +     Radio, white 20 pin plug, pin 9
Factory Amp Turn-on     Green/White     +     Radio, white 20 pin plug, pin 1
Left Front Speaker (+/-)     Blue/White - Blue/Red or Blue - White     +,-     Radio, white 20 pin plug, pins 2 - 3
Right Front Speaker (+/-)     White/Black - Blue/Black or Black - Yellow     +,-     Radio, white 20 pin plug, pins 11 - 12
Left Rear Speaker (+/-)     Lt. Blue - Black/Yellow or Blue - Brown     +,-     Radio, white 20 pin plug, pins 4 - 5
Right Rear Speaker (+/-)     Orange/Blue - Red/Blue or Black/White - Pink     +,-     Radio, white 20 pin plug, pins 13 - 14
Left Front Speaker - With Amp     Blue/White - Blue/Red (woofer); Blue/White - Blue/Red (tweeter)     +,-     Amplifier under driver seat, gray 24 pin plug, pins 11 - 23; 10 - 22
Right Front Speaker - With Amp     White/Black - Blue/Black (woofer); White/Black - Blue/Black (tweeter)     +,-     Amplifier under driver seat, gray 24 pin plug, pins 12 - 24; 9 - 21
Left Rear Speaker - With Amp     Lt. Blue - Black/Yellow     +,-     Amplifier under driver seat, gray 24 pin plug, pins 7 - 19
Right Rear Speaker - With Amp     Orange/Blue - Red/Blue     +,-     Amplifier under driver seat, gray 24 pin plug, pins 8 - 20
Center Channel - With Amp     Blue/White - Blue/Black     +,-     Amplifier under driver seat, gray 24 pin plug, pins 6 - 18
Subwoofer - With Amp     White - Black (coil 1); Brown/White - Brown (coil 2)     +,-     Amplifier under driver seat, white 8 pin plug, pins 2 - 6; 3 - 7
Aux. Audio Input Left (+/-)     Violet - Gray     +,-     Radio, white 8 pin plug, pins 4 - 2 or white 24 pin plug, pins 10 - 11
Aux. Audio Input Right (+/-)     Green - Gray     +,-     Radio, white 8 pin plug, pins 3 - 2 or white 24 pin plug, pins 12 - 11
Rearview Camera Video     Red - Red/White or Green - (shield)     +,-     Radio, white 24 pin plug, pins 16 - 15
caraudioholic24
Member - Posts: 37
Posted: December 10, 2021 at 10:11 AM / IP Logged Link to Post Post Reply Quote caraudioholic24
I typed this incorrectly. I will contact a mod to correct the title. Thank you for the info though
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
