2021 Toyota RAV4 Hybrid, Alarm Wiring
tencap
Posted: January 18, 2022 at 2:31 AM / IP Logged Link to Post Post Reply Quote tencap
Hi, looking for alarm wiring for a Toyota RAV4 Hybrid. It's mainly to add a proximity central locking key (Viper PKE) to a base model that doesn't have the OEM Smart key option. Thanks!
Platinum - Posts: 13,726
Posted: January 19, 2022 at 10:00 PM / IP Logged Link to Post Post Reply Quote i am an idiot
12 Volts      White (50A)      +      Dash Fuse Box, white 1 pin plug (4L), pin 1      Directwire
Second 12 Volts      Lavender/White (7.5A)      +      Ignition Switch, white 8 pin plug, pin 7      Directwire
Ground      (chassis ground)
Starter      Blue      +      Ignition Switch, white 8 pin plug, pin 5      Directwire
Ignition      Lavender/Red      +      Ignition Switch, white 8 pin plug, pin 8      Directwire
Accessory      Lavender/Green      +      Ignition Switch, white 8 pin plug, pin 6      Directwire
Ignition Interrupt      Lavender/Black (TPMS)      Cut      Passenger Kick, white or blue 20 pin plug (GM2), pin 12      Directwire
Keysense      Lt. Green      -      Key Switch, white 2 pin plug, pin 1
CAN Bus High      Tan      Data      Body ECU on dash fuse box, black 30 pin plug, pin 5      Directwire
CAN Bus Low      Violet      Data      Body ECU on dash fuse box, black 30 pin plug, pin 4      Directwire
CAN Bus High 2      Black (DIAG CAN)      Data      OBD-Data Link Connector, white 16 pin plug, pin 6      Directwire
CAN Bus Low 2      Violet (DIAG CAN)      Data      OBD-Data Link Connector, white 16 pin plug, pin 14      Directwire
OBD 12 Volts      Red (7.5A)      +      OBD-Data Link Connector, white 16 pin plug, pin 16      Directwire
OBD Ground      White/Black      -      OBD-Data Link Connector, white 16 pin plug, pin 4      Directwire
OBD Connector      White           Under Driver Dash, Next To Hood Release
IMMO Data      Lavender/Lt. Green (IMO)      Data      Left of Dash Fuse Box, white 20 pin plug (AG4), pin 3      Directwire
IMMO Data 2      Lavender/Blue (IMI)      Data      Left of Dash Fuse Box, white 20 pin plug (AG4), pin 14      Directwire
SIL Data      Pink      Data      OBD-Data Link Connector, white 16 pin plug, pin 7      Directwire
Security Light      Red      +      Instrument Cluster, black 38 pin plug, pin 7
RDA      Red      Data      Body ECU on dash fuse box, black 21 pin plug, pin 10      Directwire
Power Lock      (use factory alarm arm)
Power Unlock      (use factory alarm disarm)
Power Lock2      Lt. Green (passenger switch) (if needed)      -      Dash Fuse Box, rear, white 32 pin plug (4D), pin 16
Power Unlock2      Gray (passenger switch) (if needed)      -      Dash Fuse Box, rear, white 56 pin plug (4A), pin 39
Lock Motor      White      Reverse      Driver Kick, black 20 pin plug (JN1), pin 18
Driver Unlock Motor      Gray      Reverse      Driver Kick, white 18 pin plug (JG1), pin 1
Passenger Unlock Motor      Red      Reverse      Dash Fuse Box, white 36 pin plug (4H), pin 9
Factory Alarm Arm      Lt. Green (key lock)      -      Body ECU on dash fuse box, black 21 pin plug, pin 18      Directwire
Factory Alarm Disarm      Tan (key unlock)      Double -      Body ECU on dash fuse box, black 21 pin plug, pin 17      Directwire
Parking Lights      Lavender/Red      +      Dash Fuse Box, white 36 pin plug (4H), pin 30
Parking Lights -      Green      -      Headlight Switch, white 40 pin plug, pin 3      Directwire
Hazards      Pink      -      Hazard Switch, blue 6 pin plug, pin 5
Turn Signal (Left)      Lavender/Lt. Green (LF); Lavender/Tan (LR)      +      Dash Fuse Box, white 32 pin plug (4F), pin 6 (LF); Driver Kick, black 12 pin plug (GN5), pin 12 (LR)
Turn Signal (Right)      Green or Lavender/Green (RF); Lavender/Black (RR)      +      Dash Fuse Box, white 32 pin plug (4F), pin 8 (RF); Driver Kick, black 12 pin plug (GN5), pin 1 (RR)
Headlight      Red      -      Headlight Switch, white 40 pin plug, pin 4      Directwire
AutoLights      Yellow      Cut      Headlight Switch, white 40 pin plug, pin 5      Directwire
Reverse Light      Blue      +      Dash Fuse Box, white 36 pin plug (4H), pin 10
Reverse Light 2      White (alternate location)      +      Radio, gray 28 pin plug, pin 28
Left Front Door Trigger      Red      -      Body ECU on dash fuse box, black 30 pin plug, pin 1      Directwire
Right Front Door Trigger      Tan      -      Body ECU on dash fuse box, black 30 pin plug, pin 6      Directwire
Left Rear Door Trigger      Green      -      Dash Fuse Box, white 36 pin plug (4H), pin 24
Right Rear Door Trigger      Lavender/Violet      -      Dash Fuse Box, rear, white 56 pin plug (4A), pin 31
Dome Light      Lavender/Blue      -      Dash Fuse Box, rear, white 32 pin plug (4D), pin 29
Trunk/Hatch Pin      Black      -      Dash Fuse Box, white 36 pin plug (4H), pin 34
Hood Pin      Gray      - N.C.      Body ECU on dash fuse box, black 30 pin plug, pin 30      Directwire
Trunk/Hatch Release      Black (rear handle switch)      -      Body ECU on dash fuse box, black 21 pin plug, pin 13      Directwire
Trunk Release Motor      Lavender/Black      Reverse      Dash Fuse Box, white 36 pin plug (4H), pin 20
Fuel Door Release      Lavender/Blue      -      Fuel Lid Opener Switch, blue 6 pin plug, pin 5
Tachometer      (program engine checking off)
Tachometer 2      Black (if needed)      AC      Camshaft Position Sensor, engine top driver side, black 3 pin plug, pin 1
Fuel Pump      Black      +      Near Driver Firewall Grommet, white 18 pin plug (AN1), pin 1
Rear Defroster      White      Reverse      Near Driver Firewall Grommet, blue 18 pin plug (AN3), pin 12
Mirror Defroster      Lt. Green      Reverse      Left of Dash Fuse Box, gray 18 pin plug (AG2), pin 2
Wiper Deicer      Lt. Blue      - Latched      Left of Dash Fuse Box, gray 12 pin plug (AG7), pin 6      Directwire
Left Front Heated Seat      Blue      Reverse      Left Seat Heater Switch, gray 6 pin plug, pin 4
Right Front Heated Seat      Red      Reverse      Right Seat Heater Switch, white 6 pin plug, pin 4
Heated Steering Wheel      Black      + Latched      Steering Heater Switch, blue 6 pin plug, pin 2
Speed Sense      Lt. Green      AC      Radio, gray 28 pin plug, pin 27
Brake Wire      Lavender/White      +      Brake Switch, white 7 pin plug, pin 3
Parking Brake      Pink (electric parking brake)      -      Left of Dash Fuse Box, gray 12 pin plug (AG7), pin 7
Horn Trigger      Blue      -      Left of Dash Fuse Box, gray 18 pin plug (AG2), pin 17      Directwire
Horn Trigger 2      White (alternate location)      -      Dash Fuse Box, white 32 pin plug (4F), pin 27
Wipers      Green (LO); Red (HI)      -      Headlight Switch, white 40 pin plug, pin 26 (LO); pin 27 (HI)      Directwire
Wipers Protection      Black (ground)      Cut      Headlight Switch, white 40 pin plug, pin 33      Directwire
All Windows Up-Down      (use factory alarm arm/disarm)
