2022 Ford Bronco Sport, Alarm, Remote Start Wiring
bryanbr
Posted: November 16, 2022 at 3:39 PM / IP Logged Link to Post Post Reply Quote bryanbr
Can someone help me with the alarm/remote start information FORD BRONCO SPORT 2022. Thanks friends !!
tonanzith
Gold - Posts: 603
Posted: February 02, 2023 at 11:28 PM / IP Logged Link to Post Post Reply Quote tonanzith
Item     Wire Color     Polarity     Wire Location
12 Volts     Red (40A)     +     BCM in passenger footwell, black 3 pin plug (B), pin 1
Second 12 Volts     Brown/Red (7.5A)     +     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 24
Ground     (chassis ground)
Ground 2     Black/Blue     -     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 14
Starter Kill     Brown     +     Underhood Fuse Box, black 50 pin plug (A), pin 50
Ignition Sense     Green     +     BCM in passenger footwell, black 3 pin plug (B), pin 3
PTS 1     Green/White     +     Push Button Start Switch, black 6 pin plug, pin 1
PTS 2     Yellow/Orange     -     Push Button Start Switch, black 6 pin plug, pin 6
CAN Bus High     Blue (HS1 CAN)     Data     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 20
CAN Bus Low     White (HS1 CAN)     Data     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 19
CAN Bus High 2     Gray/Orange (MS CAN)     Data     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 23
CAN Bus Low 2     Violet/Orange (MS CAN)     Data     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 22
CAN Bus High 3     Green/Orange (HS2 CAN)     Data     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 18
CAN Bus Low 3     Gray/Blue (HS2 CAN)     Data     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 17
OBD 12 Volts     Yellow/Red (10A)     +     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 13
OBD Ground     Black/Gray     -     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 1
OBD Connector     Black          Under Driver Dash, Near Hood Release
IMMO Antenna     (PATS Antenna in front of center console, under rubber mat)
Power Lock     Gray/Yellow (auto down window)     -     BCM in passenger footwell, gray 72 pin plug (F), pin 25 --or-- Driver Kick, door harness
Power Unlock     Brown (auto down window)     -     BCM in passenger footwell, gray 72 pin plug (F), pin 20 --or-- Driver Kick, door harness
Power Lock2     Gray/Yellow (auto up/down window)     -     Driver Door Lock Switch, black 5 pin plug, pin 2
Power Unlock2     Violet/Gray (auto up/down window)     -     Driver Door Lock Switch, black 5 pin plug, pin 4
Lock Motor     Gray/Brown     Reverse     BCM in passenger footwell, gray 72 pin plug (F), pin 1 --or-- Driver Kick, door harness
Driver Unlock Motor     Blue/Green     Reverse     BCM in passenger footwell, gray 72 pin plug (F), pin 63 --or-- Driver Kick, door harness
Passenger Unlock Motor     Brown/Green     Reverse     BCM in passenger footwell, gray 72 pin plug (F), pin 11
Factory Alarm Arm     (arms on lock)
Factory Alarm Disarm     (proximity key and push button)
Parking Lights     Blue/Gray (LF, RF)     +     BCM in passenger footwell, gray 72 pin plug (F), pin 52
Parking Lights 2     Violet/Green (LR); White/Orange (RR)     +     BCM in passenger footwell, gray 72 pin plug (F), pin 53 (LR); pin 48 (RR)
Parking Lights -     (LIN)
Hazards     Brown/Yellow     -     BCM in passenger footwell, black 72 pin plug (D), pin 12
Hazards 2     Brown/Yellow (alternate location)     -     Audio Control Panel, black 12 pin plug, pin 7
Turn Signal (Left)     Blue/Green (LF); Gray/Orange (LR)     +     BCM in passenger footwell, black 50 pin plug (E), pin 3 (LF); gray 72 pin plug (F), pin 6 (LR)
Turn Signal (Right)     Yellow/Violet (RF); Green/Orange (RR)     +     BCM in passenger footwell, black 50 pin plug (E), pin 2 (RF); gray 72 pin plug (F), pin 65 (RR)
Headlight     Brown/Blue (L); Blue/Green (R)     +     BCM in passenger footwell, black 50 pin plug (E), pin 1 (L); pin 39 (R)
AutoLights     (open left front door trigger to turn off)
Reverse Light     Green/Brown     +     BCM in passenger footwell, gray 72 pin plug (F), pin 66
Left Front Door Trigger     Green/Violet     - N.C.     BCM in passenger footwell, gray 72 pin plug (F), pin 29 --or-- Driver Kick, door harness
Right Front Door Trigger     White     - N.C.     BCM in passenger footwell, gray 72 pin plug (F), pin 32
Left Rear Door Trigger     Green     - N.C.     BCM in passenger footwell, gray 72 pin plug (F), pin 33
Right Rear Door Trigger     Yellow     - N.C.     BCM in passenger footwell, gray 72 pin plug (F), pin 34
Dome Light     Gray/Violet     +     BCM in passenger footwell, gray 72 pin plug (F), pin 17
Trunk/Hatch Pin     Yellow/Orange     - N.C.     BCM in passenger footwell, gray 72 pin plug (F), pin 16
Rear Glass Pin     (same as hatch pin)
Hood Pin     Blue/Orange     - N.C.     BCM in passenger footwell, black 50 pin plug (E), pin 26
Trunk/Hatch Release     Gray/Yellow (rear handle switch)     -     BCM in passenger footwell, gray 72 pin plug (F), pin 31
Trunk-Hatch Release2     Brown/Yellow (hatch glass) (rear handle switch)     -     BCM in passenger footwell, gray 72 pin plug (F), pin 28
Trunk Release Motor     Green/White     Reverse     BCM in passenger footwell, gray 72 pin plug (F), pin 10
Trunk Release Motor 2     Brown/Yellow (hatch glass)     +     Above Passenger Kick, 40 pin plug (C219), pin 24
Tachometer     Brown (1.5L)     AC     Camshaft Position Sensor, engine driver side top, black 3 pin plug, pin 3
Tachometer 2     Brown/Blue (2.0L)     AC     Camshaft Position Sensor, engine driver side top, gray 3 pin plug, pin 3
Fuel Pump     Violet/Red     +     Driver Kick, harness to rear
Rear Defroster     Yellow/Orange     + Latched     Above Passenger Kick, 40 pin plug (C219), pin 37
Mirror Defroster     (same as rear defroster, auto down window); (MS CAN, auto up/down window)
Wiper Deicer     Violet/White (wiper); White (windshield)     + Latched     Underhood Fuse Box, black 50 pin plug (A), pin 47 (wiper); gray 50 pin plug (B), pin 48 (windshield)
Left Front Heated Seat     (MS CAN)
Right Front Heated Seat     (MS CAN)
Heated Steering Wheel     (MS CAN)
Speed Sense     Yellow/Orange (1.5L); Brown/Red (2.0L)     AC     PCM below driver headlight, black 95 pin plug, pin 68
Brake Wire     Violet/White     +     Brake Switch, white 4 pin plug, pin 4
Brake Wire 2     Violet/White (alternate location)     +     BCM in passenger footwell, black 72 pin plug (D), pin 8
Parking Brake     (electric parking brake)
Horn Trigger     Green/White     -     Horn Switch-Clock Spring, gray 18 pin plug, pin 9
Horn Trigger 2     Green/White (alternate location)     -     BCM in passenger footwell, black 72 pin plug (D), pin 26
Wipers     (LIN)
Left Front Window (Up/Down)     Blue/Gray - Yellow/Violet (auto down); Blue - Green (auto up/down)     A     Driver Window Switch, gray 4 pin plug, pins 4 - 2 (auto down); Driver Door Module, gray 24 pin plug, pins 1 - 13 (auto up/down)
Right Front Window (Up/Down)     White/Orange - Blue/White (w/o auto); White - Gray/Yellow (with auto)     A     Passenger Window Switch, green 8 pin plug, pins 6 - 7 (w/o auto); Passenger Door Module, gray 24 pin plug, pins 1 - 13 (with auto)
Left Rear Window (Up/Down)     Green/Violet - Brown (w/o auto); Gray/Brown - Violet/Orange (with auto)     A     Left Rear Window Switch, green 8 pin plug, pins 6 - 7 (w/o auto); Driver Kick, door harness (with auto)
Right Rear Window (Up/Down)     White/Violet - Gray (w/o auto); Violet/White - Yellow/Orange (with auto)     A     Right Rear Window Switch, green 8 pin plug, pins 6 - 7 (w/o auto); Passenger Kick, door harness (with auto)
Sun Roof (Open/Close)     Violet/Brown - Yellow/Orange (function with ignition on only)     -     Left Front Pillar, 22 pin plug (C215), pins 5 - 16
Radio 12V     White/Red     +     Radio behind HVAC controls, black 32 pin plug, pin 1
Radio Ground     Black/Gray     -     Radio behind HVAC controls, black 32 pin plug, pin 4
Radio Ignition     Yellow/Orange (delayed accessory)     +     Driver Kick, door harness --or-- BCM in passenger footwell, gray 3 pin plug (C), pin 3
Factory Amp Turn-on     Yellow/Violet (audio signal is A2B)     +     Radio behind HVAC controls, gray 32 pin plug, pin 23
Left Front Speaker (+/-)     Blue - Gray/Brown     +,-     Radio behind HVAC controls, black 32 pin plug, pins 8 - 7
Right Front Speaker (+/-)     Yellow/Orange - Green/Brown     +,-     Radio behind HVAC controls, black 32 pin plug, pins 3 - 2
Left Rear Speaker (+/-)     Gray/Violet - Brown/Green     +,-     Radio behind HVAC controls, black 32 pin plug, pins 6 - 5
Right Rear Speaker (+/-)     Green/Violet - Gray     +,-     Radio behind HVAC controls, black 32 pin plug, pins 10 - 9
Left Front Speaker - With Amp     White - White/Brown     +,-     Amplifier in left rear quarter panel, black 20 pin plug, pins 17 - 7
Right Front Speaker - With Amp     White/Violet - White/Orange     +,-     Amplifier in left rear quarter panel, black 20 pin plug, pins 16 - 6
Left Front Tweeter - With Amp     Gray/Blue - Brown     +,-     Radio behind HVAC controls, black 32 pin plug, pins 5 - 6
Right Front Tweeter - With Amp     White/Orange - Green/Violet     +,-     Radio behind HVAC controls, black 32 pin plug, pins 9 - 10
Left Rear Speaker - With Amp     White/Green - Brown/Yellow     +,-     Amplifier in left rear quarter panel, black 20 pin plug, pins 20 - 10
Right Rear Speaker - With Amp     Brown/White - Brown/Blue     +,-     Amplifier in left rear quarter panel, black 20 pin plug, pins 18 - 8
Center Channel - With Amp     Brown/Blue - White     +,-     Radio behind HVAC controls, black 32 pin plug, pins 3 - 2
Subwoofer - With Amp     Green/Violet - Gray     +,-     Amplifier in left rear quarter panel, black 20 pin plug, pins 15 - 5
Aux. Audio Input Left (+/-)     Blue - Gray/Orange (SYNC audio)     +,-     Radio behind HVAC controls, gray 32 pin plug, pins 20 - 31
Aux. Audio Input Right (+/-)     Violet/Green - Brown/White (SYNC audio)     +,-     Radio behind HVAC controls, gray 32 pin plug, pins 21 - 32
Rearview Camera Video     Green/Blue - Violet/Gray     +,-     SYNC Module behind HVAC controls, black 54 pin plug, pins 14 - 15 --or-- Above Passenger Kick, 40 pin plug (C207), pins 18 - 29
Gary Sather
Thursday, April 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
