2020 Kia Sportage, Push To Start, Alarm Wiring
automonster
Member - Posts: 6
Posted: January 17, 2023 at 7:20 PM / IP Logged Link to Post Post Reply Quote automonster
Anyone got the wiring for installing an alarm on a 2020 kia sportage press start
tonanzith
Gold - Posts: 603
Posted: February 02, 2023 at 11:24 PM / IP Logged Link to Post Post Reply Quote tonanzith
Item     Wire Color     Polarity     Wire Location
12 Volts     Green (50A)     +     SJB-Dash Fuse Box, black 6 pin plug (B), pin 2
Ground     (chassis ground)
Starter     Yellow/Orange     +     Driver Kick, blue 49 pin plug (MC11), pin 3
Ignition     Blue     +     Driver Kick, blue 49 pin plug (MC11), pin 19
Second Ignition     Pink     +     Driver Kick, blue 49 pin plug (MC11), pin 31
Accessory     Pink (not required)     +     Driver Kick, blue 49 pin plug (MC11), pin 4
Ignition Interrupt     Yellow     Cut     SJB-Dash Fuse Box, rear, white 40 pin plug (F), pin 13
PTS 1     White     -     Smart Key Control Module above gas pedal, black 20 pin plug, pin 3
PTS 2     Green/Black     -     Smart Key Control Module above gas pedal, black 20 pin plug, pin 13
CAN Bus High     White (C-CAN)     Data     OBD-Data Link Connector, black 16 pin plug, pin 6
CAN Bus Low     Brown (C-CAN)     Data     OBD-Data Link Connector, black 16 pin plug, pin 14
CAN Bus High 2     Blue (B-CAN)     Data     SJB-Dash Fuse Box, rear, white 40 pin plug (F), pin 22
CAN Bus Low 2     Red (B-CAN)     Data     SJB-Dash Fuse Box, rear, white 40 pin plug (F), pin 21
OBD 12 Volts     Red (7.5A)     +     OBD-Data Link Connector, black 16 pin plug, pin 16
OBD Ground     Black     -     OBD-Data Link Connector, black 16 pin plug, pin 4
OBD Connector     Black          Under Driver Dash, Below Fuse Panel Cover
IMMO Data     White/Orange     Data     Driver Kick, blue 49 pin plug (MC11), pin 12
Power Lock     Blue/Black     -     SJB-Dash Fuse Box, white 40 pin plug (D), pin 16
Power Unlock     Gray/Orange     -     SJB-Dash Fuse Box, white 40 pin plug (D), pin 31
Power Unlock - Driver Door     Yellow/Black     -     SJB-Dash Fuse Box, rear, white 40 pin plug (F), pin 26
Lock Motor     Orange     Reverse     SJB-Dash Fuse Box, white 38 pin plug (C), pin 26
Driver Unlock Motor     Blue     Reverse     Driver Kick, white 68 pin plug (MF11), pin 35
Passenger Unlock Motor     Pink     Reverse     SJB-Dash Fuse Box, white 38 pin plug (C), pin 17
Factory Alarm Arm     Red (see Tech Doc 1300)     -     SJB-Dash Fuse Box, white 40 pin plug (D), pin 17
Factory Alarm Disarm     Pink (see Tech Doc 1300)     Double -     SJB-Dash Fuse Box, white 40 pin plug (D), pin 18
Lock Detection     White (see Tech Doc 1300)     Open     SJB-Dash Fuse Box, white 40 pin plug (D), pin 34
Unlock Detection     (same as lock detection)     -
Parking Lights     Yellow/Orange (LF); Yellow (RF)     +     SJB-Dash Fuse Box, black 38 pin plug (A), pin 9 (LF); pin 17 (RF)
Parking Lights 2     Blue/Orange (LR); Pink/Black (RR)     +     SJB-Dash Fuse Box, white 38 pin plug (C), pin 7 (LR); pin 16 (RR)
Parking Lights -     Yellow (relay isolate from switch)     - 1680 Ohms     Headlight-Wiper Switch, black 16 pin plug, pin 14
Parking Lights MUX     Yellow     MUX     Headlight-Wiper Switch, black 16 pin plug, pin 14
Hazards     Orange     -     SJB-Dash Fuse Box, rear, white 40 pin plug (F), pin 28
Turn Signal (Left)     Red/Orange (LF); Yellow/Black (LR)     +     SJB-Dash Fuse Box, black 38 pin plug (A), pin 35 (LF); white 38 pin plug (C), pin 14 (LR)
Turn Signal (Right)     White (RF); White (RR)     +     SJB-Dash Fuse Box, black 38 pin plug (A), pin 30 (RF); white 38 pin plug (C), pin 25 (RR)
Headlight     White     -     Headlight-Wiper Switch, black 16 pin plug, pin 15
AutoLights     Yellow     - 680 Ohms (Off)     Headlight-Wiper Switch, black 16 pin plug, pin 14
Reverse Light     Blue/Orange     +     SJB-Dash Fuse Box, white 38 pin plug (C), pin 32
Left Front Door Trigger     Green/Orange     -     SJB-Dash Fuse Box, white 40 pin plug (D), pin 37
Right Front Door Trigger     Brown     -     SJB-Dash Fuse Box, white 40 pin plug (D), pin 38
Left Rear Door Trigger     White     -     SJB-Dash Fuse Box, white 40 pin plug (D), pin 40
Right Rear Door Trigger     Black     -     SJB-Dash Fuse Box, white 40 pin plug (D), pin 20
Dome Light     Pink     -     Left Front Pillar, white 42 pin plug (MR11), pin 4
Trunk/Hatch Pin     Pink or Pink/Black     -     SJB-Dash Fuse Box, white 40 pin plug (D), pin 33
Hood Pin     Gray     -     SJB-Dash Fuse Box, black 38 pin plug (A), pin 7
Power Liftgate     White     -     Power Liftgate Switch, white 24 pin plug, pin 16
Power Liftgate 2     White (alternate location)     -     Driver Kick, white 68 pin plug (MF11), pin 64
Trunk/Hatch Release     Yellow (rear handle switch)     -     SJB-Dash Fuse Box, white 40 pin plug (D), pin 30
Trunk Release Motor     Blue     +     SJB-Dash Fuse Box, white 38 pin plug (C), pin 24
Fuel Door Release     (locks-unlocks with driver door)
Tachometer     White/Black     AC     Driver Kick, blue 49 pin plug (MC11), pin 18
Tachometer 2     White (2.4L, 2.0L-T)     AC     Camshaft Position Sensor, engine driver side front, gray 3 pin plug, pin 3
Fuel Pump     White     +     Above Driver Kick, white 24 pin plug (CF11), pin 1
Rear Defroster     White     - Latched     SJB-Dash Fuse Box, black 38 pin plug (A), pin 6
Mirror Defroster     (same as rear defroster)
Wiper Deicer     Blue     - Latched     SJB-Dash Fuse Box, rear, white 40 pin plug (F), pin 25
Left Front Heated Seat     Red     -     Front Heater Switch, white 24 pin plug, pin 23
Right Front Heated Seat     Brown     -     Front Heater Switch, white 24 pin plug, pin 14
Heated Steering Wheel     Yellow     -     Steering Wheel Heater Switch, white 24 pin plug, pin 18
Speed Sense     Brown     AC     Radio, white 38 pin plug, pin 38
Brake Wire     Yellow     +     SJB-Dash Fuse Box, black 38 pin plug (A), pin 14
Brake Wire 2     Yellow (alternate location)     +     Brake Switch, black 6 pin plug, pin 5
Parking Brake     Green/Orange (w/o EPB)     -     Driver Kick, blue 49 pin plug (MC11), pin 46
Horn Trigger     Yellow/Black     -     Driver Kick, blue 49 pin plug (MC11), pin 43
Horn Trigger 2     Yellow/Black (alternate location)     -     Horn Switch-Clock Spring, white 14 pin plug, pin 8
Horn - Factory Alarm     Pink     -     SJB-Dash Fuse Box, black 38 pin plug (A), pin 33
Wipers     Blue     +     Driver Kick, blue 49 pin plug (MC11), pin 25
Left Front Window (Up/Down)     White - Pink (auto down); (auto up-down, motor is part of module)     A     Power Window Main Switch, white 18 pin plug, pins 7 - 8
Right Front Window (Up/Down)     Gray - Pink (w/o auto); (auto up-down, motor is part of module)     A     Driver Kick, door harness
Left Rear Window (Up/Down)     Blue - Yellow     A     Driver Kick, door harness
Right Rear Window (Up/Down)     Green - Orange     A     Driver Kick, door harness
Sun Roof (Open/Close)     Pink and White (open) (functions with ignition on only)     Both -     Sunroof Switch, white 6 pin plug, pins 5, 6
Sun Roof (Limit/Close)     Orange and White (close) (functions with ignition on only)     Both -     Sunroof Switch, white 6 pin plug, pins 3, 2
Radio 12V     Red     +     Radio, white 35 pin plug, pins 10, 11
Radio Ground     Black     -     Radio, white 35 pin plug, pins 12, 13
Radio Ignition     Blue     +     Radio, white 35 pin plug, pin 22
Radio Illumination     Red (parking lights); Blue (dimmer)     +,-     Radio, white 35 pin plug, pin 6 (parking lights); pin 19 (dimmer)
Factory Amp Turn-on     (M-CAN) (audio is SPDIF)
Power Antenna     Green     +     Radio, white 35 pin plug, pin 5
Left Front Speaker (+/-)     White - Brown     +,-     Radio, white 38 pin plug, pins 13 - 14
Right Front Speaker (+/-)     Red - Blue     +,-     Radio, white 38 pin plug, pins 16 - 15
Left Rear Speaker (+/-)     Black - Yellow     +,-     Radio, white 38 pin plug, pins 1 - 2
Right Rear Speaker (+/-)     Green - Orange     +,-     Radio, white 38 pin plug, pins 28 - 27
Left Front Speaker - With Amp     White - Brown     +,-     Amplifier in right rear cargo floor, black 28 pin plug, pins 4 - 19
Right Front Speaker - With Amp     Red - Blue     +,-     Amplifier in right rear cargo floor, black 28 pin plug, pins 3 - 18
Left Rear Speaker - With Amp     Black - Yellow     +,-     Amplifier in right rear cargo floor, black 28 pin plug, pins 13 - 26
Right Rear Speaker - With Amp     Green - Orange     +,-     Amplifier in right rear cargo floor, black 28 pin plug, pins 12 - 25
Center Channel - With Amp     Pink - Blue     +,-     Amplifier in right rear cargo floor, black 28 pin plug, pins 14 - 27
Subwoofer - With Amp     Green - Orange (coil 1); Blue - Red (coil 2)     +,-     Amplifier in right rear cargo floor, black 28 pin plug, pins 2 - 17 (coil 1); pins 1 - 16 (coil 2)
Rearview Camera Video     Yellow - Brown     +,-     Radio, white 38 pin pl
Gary Sather
