Wiring Information
the12volt
Administrator - Posts: 3,957
Posted: March 08, 2002 at 9:22 AM / IP Logged
I'll be writing the user section for the vehicle information database that will allow members to create and edit new records. Once completed, members that are providing information as a result of a request  by other members are encouraged to add any wiring information to this database. This will make searching for such information quick and simple. Currently there are nearly 3000 records.  If you are logged in, you can view them here:
https://www.the12volt.com/installbay/vehicles.asp.
In the meantime please post new wiring information in this forum.
the12volt
darryl
Posted: March 20, 2002 at 1:27 AM / IP Logged
what's up? i need a wiring diagram for a 2001 Chevy Tracker. i'm trying to install a kenwood cd receiver kdc-v6017. but i ran into problems because the new wire harness colors are different from my original cd wire harness. thanks
db1979
Moderator - Posts: 12,488
Posted: March 20, 2002 at 5:10 AM / IP Logged
Most of the wiring harnesses that are made today use the aftermarket wire colors as their wire colors. You can most likely just use the wire harness colrs and match them up with the Kenwood deck and it will work fine. Also, if you look closely at the wires ( in most cases ) the wire description is on there, eg. power, ground, left fron speaker, etc.....
wjperki
Posted: March 25, 2002 at 8:32 AM / IP Logged
HELP!  I am trying to find a wiring diagram for a 1987 Cutlass Supreme's cruise control.  I have power going from the fuse box to the switch, but nothing goes under the hood.  I was able to trace the hot wire from the fuse box to one of the brake switches and up to the on/off switch.  Leaving the brake switch to the servo and actuator, i get nothing.  Any suggestions??
Continued here: https://www.the12volt.com/installbay/display_topic_threads.asp?ForumID=7&TopicID=136
bobnmiss
Posted: May 28, 2002 at 12:15 PM / IP Logged
wiring diagram for 96 ford contour factory tape deck. am trying to install a cd player. please help.
the12volt
Posted: May 28, 2002 at 12:45 PM / IP Logged
donnie43040
Posted: May 29, 2002 at 6:44 PM / IP Logged
Hello! I recently purchased a 1982 ford lincoln towncar. The previous owner thinks of himself as a great mechanic. I on the other hand am not to proud to ask for help. I need diagrams for the charging system and vacuum system.
donnie
