installing an amp in a 2000 ford f150
vanceti
Posted: June 21, 2003 at 10:37 AM / IP Logged
 hey man i got a problem the amp is getting feed back  when i turn off the truck and turn it back on the woofer will no longer work or the truck left speakers. i hooked up the wires to the leftspeakers to get the signal to the amp. i grounded it to the back seats. it will work when i mess with the ground or when i disconnect  the speaker and put it back but then i turn off the radio and it has feed  back and then turn off the truck . then turn it on and it wont come on again till i play with the wires all over again. i changed the ground  adn changed where i hooked up the power wire
please get back to me asap
esmith69
Gold - Posts: 1,511
Posted: June 24, 2003 at 1:50 PM / IP Logged
Try a different grounding point, perhaps one directly on the chassis of the vehicle if possible.  Also, how did you hook up the amp's remote turn on connection?
Ethan
Donate to the12volt.com
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
