Rostra Cruise control for Land cruiser
wbashaiba
Posted: July 11, 2003 at 11:14 AM / IP Logged
Anybody installed a rostra cruise control kit and swtch  (part# 250-1223 & 250-3743 control switch). please if you have any idea where i can locate the VSS and Tach wire in my land cruiser 6cylinder manual transmission. i installed the kit and the handle but i stacked in locating the VSS & Tach wire. the ifromatio which on this location https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1999&make=Toyota&model=Landcruiser&ID=19012&type=Cruise
on this locaion mentioned that the Tach meter is test connector ???? what this means?????
Do I need signal generator to make this kit work OR what>>>>>?
please if ou have any info about this subject e -mail me  wald7887@emirates.net.ae
Waleed Moh'd
Platinum - Posts: 12,488
Posted: July 12, 2003 at 6:48 PM / IP Logged
SPEED SENSE                  | purple I             behind the glove box *8
Located in a 28 pin connector at the ECM behind the glove box.
