98 maxima wiring diagram
delio
Posted: July 01, 2002 at 2:57 PM / IP Logged
Anyone have the wiring diagram sheet for the 98 Maxima GXE. It would be greatly appreciated. Anyone have pinouts for the 5 Speed ECU either?
Platinum - Posts: 12,488
Posted: July 01, 2002 at 9:33 PM / IP Logged
Nissan
Maxima
1996-1999
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ GREEN & BLK/WHT
OR BLK/YEL IGN. SWITCH HARNESS **
Ignition  #1:
BLACK/ RED
IGNITION SWITCH HARNESS
Ignition #2:
RED / YELLOW
Ignition  #3:
N/A
Accessory:
WHITE/ BLUE
Brake  Light:
RED / GREEN (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
WHITE/ GREEN
AT ENGINE CONTROL MODULE *
Parking Lights:
RED / GREEN (+)
AT HEADLIGHT SWITCH
Headlights:
GREEN/ YELLOW (DR) &
BLUE/BLACK (PS) (+) AT HEADLIGHT SW.
OEM Alarm  Disarm:
GREEN/ YELLOW (-)
IN DRIVER DOOR (DRIVER SWITCH)
OEM Alarm  Arm:
L GREEN/ RED (-)
AT LOCAL CONTROL UNIT
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Engine Control Module Located Behind Center Console. ** This Vehicle Is Equipped With Two Start Wires. Both Must Be Powered In Order For Vehicle To Start When Engine Is Cold
Nissan
Maxima
1996-1999
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE/ PURPLE
Starter  Kill:
Ignition  +12 Volts:
BLACK/ RED
Dome  Lights/Superv:
RED / WHITE (-)
AT BODY CONTROL MODULE ***
OEM Horn:
GREEN / WHITE (-)
STEERING COLUMN HARNESS
Power  Lock:
LIGHT GREEN/ RED
AT LOCAL CONTROL UNIT (DR. SWITCH)****
Power  Unlock:
GREEN/ YELLOW
Trunk  Release:
PURPLE / YELLOW (-)
AT TRUNK RELEASE SWITCH
Alarm  Input Wire:
RED / WHITE (-)
Notes:
*** Body Control Module Located Behind Center Console Underneath A/T Control Module. RED / WHITE (-) Wire Also Found At Interior Fuse Panel. ****  Double Pulse Door Lock
delio
Posted: July 02, 2002 at 9:06 AM / IP Logged
Very much appreciated. 98 maxima wiring diagram -- posted image.
