wiring
softballer
Posted: July 21, 2003 at 8:23 PM / IP Logged
Need help on installing the Mantis 1200 auto start remote w/ armed. The wiring diagram I need to get started on I have a 1994 Chevy Van G-20. Thank you
clarence cox
Platinum - Posts: 12,488
Posted: July 22, 2003 at 1:13 AM / IP Logged
|              12V|red                 |+  |ignition harness *1         |
|          STARTER|purple              |+  |ignition harness *1         |
|         IGNITION|pink                |+  |ignition harness *1         |
|        ACCESSORY|orange              |+  |ignition harness *1         |
|       POWER LOCK|lt. blue            |+  |door boot or behind cluster |
|     POWER UNLOCK|black               |+  |door boot or behind cluster |
| PARKING LIGHTS +|brown               |   |light switch                |
|       HEADLIGHTS|yellow              |+  |light switch                |
|     DOOR TRIGGER|white               |-  |pinswitch or *2             |
|  TRUNK/HATCH PIN|tied in with doors  |   |                            |
|       TACHOMETER|white               |   |coil on top of motor        |
|       BRAKE WIRE|white               |+  |at brake switch             |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|purple              |+  |wiper switch                |
|  LF WINDOW UP/DN|dk. blu - brown     |A  |in drivers door             |
|  RF WINDOW UP/DN|blue - wht/tan      |A  |in drivers door             |
Notes:
*1 The ignition harness is on top of the steering column. It is easier to access by removing the instrument cluster and removing the two 15mm bolts that hold the steering column.  *2 Also found behind instrument cluster.
