Request: Wiring Diagram 2002 Ford Explr-Sportrack
bluescreen
Posted: July 04, 2002 at 11:03 PM / IP Logged
Any help with the wiring diagram for the 2002 Ford Explorer Sportrac would be appreciated
Platinum - Posts: 12,488
Posted: July 05, 2002 at 5:16 AM / IP Logged
|              12V|yellow              |+  |ignition harness            |
|          STARTER|RED / lt. blue        |+  |ignition harness            |
|         IGNITION|lt GREEN/ purple     |+  |ignition harness            |
|        ACCESSORY|brown *1            |+  |ignition harness            |
| SECOND ACCESSORY|BLACK/ green         |+  |ignition harness            |
|       POWER LOCK|pink / YELLOW         |*8 |driver's kick panel         |
|     POWER UNLOCK|pink/lt green *9    |*8 |driver's kick panel         |
|       LOCK MOTOR|pink/black          |   |driver's kick panel         |
|     UNLOCK MOTOR|RED / orange          |   |driver's kick panel         |
|    DISARM DEFEAT|pink/orange *2      |   |driver's kick panel         |
| PARKING LIGHTS +|wht/blk or brown    |   |headlight switch or DKP     |
| PARKING LIGHTS -|WHITE/ purple        |   |*3                          |
|       HEADLIGHTS|RED / yellow          |+  |headlight switch            |
|     DOOR TRIGGER|*4                  |-  |*4                          |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|WHITE/ purple        |-  |driver's kick panel         |
|         HOOD PIN|tan/lt.green        |-  |driver's kick panel         |
|  FCTRY ALARM ARM|arms on lock *5     |   |                            |
|FCTRY ALRM DISARM|dk. GREEN/ purple    |-  |driver's kick panel         |
|       TACHOMETER|tan / YELLOW          |   |PCM *6                      |
|      SPEED SENSE|gray/black          |8  |PCM *6                      |
|       BRAKE WIRE|lt green            |+  |driver's kick, brake switch |
|     HORN TRIGGER|yellow/lt. green    |-  |steering column             |
|           WIPERS|wht & dk.blu/org *7 |+  |wiper motor or relay        |
|  LF WINDOW UP/DN|wht/blk - red       |A  |at motor in dr door         |
|  RF WINDOW UP/DN|wht/yel - tan/lt.blu|A  |sw dr door or dr kick       |
|  LR WINDOW UP/DN|yel/lt.blu - gry/org|A  |sw dr door or dr kick       |
|  RR WINDOW UP/DN|yel/blk - RED / blk   |A  |sw dr door or dr kick       |
Notes:
NOTE:  Some models of this vehicle are equipted with PATS (Passive Anti Theft System).   *1  Two brown wires at switch, both have to be powered for remote start.  *2  You may also use the pink/green power unlock wire.  *3  On early production vehicles it is in the driver kick panel, in the harness to the rear of the vehicle. On late production vehicles it is behind the glove box at the central security module.  *4 In the drivers door harness find yellow/black for the drivers door. In the drivers kick panel find lt. GREEN/ YELLOW for the drivers rear door.  In the passengers kick panel find gray/red for the passenger front door, and pink/lt. blue for the passengers rear door.  All four wires are negative trigger and must be diode isolated together.   *5  Arms on lock only with door open. It is necessary to send a signal to door    trigger as well as lock to arm factory alarm.   *6  The PCM is located at the top of the firewall towards the passenger side, the tan / YELLOW tach wire is also found at the back of the instrument cluster. Can also use any tan/stripe at the coil pack.  *7  Also found yellow/white(-) at the firewall connector.  *8  On models with keyless entry the doorlocks are negative trigger. Without keyless entry they are 5wi reverse polarity.  *9 The GEM in this vehicle shuts down after the doors have been locked for a certain time period, to "wake-up" the system .
LaterDays
Posted: November 07, 2002 at 2:57 AM / IP Logged
X-actly what I needed.
Thanx
roulmd
Member - Posts: 24
Posted: November 12, 2002 at 1:06 PM / IP Logged
On the *9 in the diagram, do I need to use a relay wired for the negative door lock system in order to unlock the doors, or how do I wake up the GEM on the Sport Trac.  I can not unlock my doors if I lock them with the keypad, unless I start my sport trac first.
Player69
Silver - Posts: 504
Posted: November 12, 2002 at 1:13 PM / IP Logged
You need to add a relay to triger the ignition wire and also your transponder bypass to pulse before unlock.
roulmd
Member - Posts: 24
Posted: November 12, 2002 at 2:00 PM / IP Logged
Please elaborate a bit on this - I am a novice at this - how would I wire that relay, and why does the transponder bypass have to pulse?  I have a diagram for a negative lock system, using a 30 amp relay, which would use the power supplied with my aftermarket keyless entry system to generate the negative trigger, will that let me use the unlock wire without waking up the GEM??
Player69
Silver - Posts: 504
Posted: November 12, 2002 at 2:53 PM / IP Logged
What type of remote start do you have?  Does it have external or internal relays?
No that will not work.  You have to power up the ignition and the transponder bypass in order to wake up the GEM.  The reason you need to power pulse the transponder pypass is because if you just power up the ignition wire you will trip the factory alarm which will likely prevent the truck from starting for a few minutes.
roulmd
Member - Posts: 24
Posted: November 12, 2002 at 3:44 PM / IP Logged
I have a Dynatech CRS600OP, which has internal relays as far as I can tell.  I had this installed, but they did a half job, and did not have it wired correctly, and did not hook up the door lock and unlock.  I have re-wired it to where it works correctly, but can't get the unlock to work if I do not lock it with the remote start keyless entry.  I have a 2001 Sport Trac, but it is basically the same wiring diagram.  Here is how it is wired up now:
6 Pin Main Harness
Red Wires (2): +12 VDC Main Power Source Input - Connected to Fuse Power
Brown:  Ignition 2 - Switched +12 VDC Output - This wire is not hooked up
Yellow:  Ignition 1 - Switch +12 VDC Output - Connected to Ignition switch
Orange: Accessory +12 VDC Output - Heater/Air - Connected to Accessory wire
Violet:  Starter Output +12 VDC - Connected to Starter Wire
The remote starter portion of the unit works great - here is the 10 pin harness hookups:
Yellow: +12 VDC Input for Brake Switch - Connected to Brake Wire
Violet: Shock Sensor Bypass Sensor Side - Not Connected
Blue: Negative Hood Trigger Input - Connected to installed hood pin
Green: Tach Sense - connected to tach wire
Gray: 500 Ma Negative Output when Running - connected to Transponder Bypass kit
Orange: Negative Starter Trigger Input - Connected to lock motor - Pink/Black wire to use factory keyless entry to activate starter unit.  I tied this in at the passenger side kick panel because of ease to locate.
Black: System Ground
Brown: Shock Sensor Bypass Alarm Side - Not Connected
Red: +12 Volt Power for System Electronics - Connected to fused 12 Volts
White: +12 VDC Output for Flashing Parking Lights - connected to parking lights
3 Pin Doorlock Connector
Green: Negative Door Lock Pules Output - Connected to power lock (Pink / YELLOW) in passenger kick panel due to ease to locate
Red: +12 VDC OUtput - Used to Energize the doorlock relays only (Pin 85 or 86) Not connected
Blue: Negative Unlock Pulse Output - connected to door unlock Pink/Lt Green in passenger kick pannel
3 Pin Accesory Plug
GREEN/ Black Stripe: Trunk Release Negative Output - not used
Red: Factory Alarm Disarm Negative Output - not connected
Yellow: Vacuum Switch Input - not connected
I would be glad to fax the manual to anyone to look at who could possibly help me correct my installation.  The remote starter portion works great - and the door lock and unlock work unless I lock the doors with the factory remote, the door lock switch, or the keypad.  Then when I try to use the remote starter unlock - it will not unlock the doors.  I would like to be able to do away with my factory remote, since the factory remote will not operate if the ignition is activated on a Ford.  I am a novice at this, and live in a remote area, and the only people around here who do these installs, are who did mine, and did not do it correctly.  Thanks to anyone in advance who can help me hook this up correctly.  I am also concerned that I am activating and de-activating my factory alarm on the 2001 Sport Trac correctly as well.
demarco
Posted: November 15, 2002 at 1:28 PM / IP Logged
I AM HAVING TROUBLE FINDING (2) THINGS.
1) I AM HAVING TROUBLE FINDING A STEREO WIRING DIAGRAM FOR A 2002 CHEVY TRACKER.
2) I HAVE A (I KNOW ITS OLD BUT !) LEGACY LSC5 MONITOR AND I CANNOT FIND A WIRING KIT FOR IT SO I CAN HAVE A TV IN MY RIDE.
DOES ANYONE KNOW WHERE I CAN FIND THESE THINGS ?
IF SO PLEASE LET ME KNOW .
THANKS
DeMarco Wilson
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
