2000 honda accord coupe window diagram?
jac2
Member - Posts: 36
Posted: September 18, 2003 at 8:34 PM / IP Logged
i need a wire diagram for 2000 honda accord v6 coupe.i already know it, but i just need wires that can control passenger  side window from   drivers side .so i dont have to drag a wire all the way from passengers side.any help?
rpm510
Member - Posts: 7
Posted: September 19, 2003 at 8:02 AM / IP Logged
98-00 Honda Accord
Wire/Function Polarity Wire Color Wire Location
12 VOLTS
STARTER
IGNITION
2nd IGNITION
ACCESSORY
POWER LOCK
POWER UNLOCK
LOCK MOTOR
UNLOCK MOTOR
DISARM DEFEAT
PARKING LIGHTS
PARKING LIGHTS
HEADLIGHTS
DOOR TRIGGER
TRUNK/HATCH PIN
FCTRY ALARM ARM
FCTRY ALARM DISARM
DISARM NO UNLOCK
TACHOMETER
BRAKE WIRE
HORN TRIGGER
WIPERS
SPEED SENSE
LF WINDOW UP/DN
RF WINDOW UP//DN
LR WINDOW UP/DN
RR WINDOW UP/DN
n/a
A
A
A
A
White
BLACK/ white *1
BLACK / YELLOW
yellow
wht/black
BLACK/ blue *2
orange
WHITE/ red
*4
lt. GREEN/ red
RED / blk
RED / yellow *6
blue/red
BLACK/ white
orange
*9
*9
blue
blue
WHITE/ black
lt. GREEN/ blue
blue/white
RED / yellow RED / blue
blue/white blue / YELLOW
ign. harness
ign. harness
ign. harness
ign. harness
ign. harness
passenger fuse box *3
driver's fuse box
driver's fuse box
*5
driver's fuse box
steering column
steering column
passenger fuse box *7
driver's kick panel *8
*10
tach test connector *11
brake pedal switch
steering column driver's door switch RF window switch LR window switch RR window switch
Notes:
This vehicle has an immobilizer system that needs to be bypassed when adding a remote start.
*1 Must interrupt the wire between the keyswitch and the fusebox, not between the fusebox and the starter, to keep the check engine light from coming on.
*2 Use BLACK/ white for lock and GREEN/ red for unlock on LX models without factory security. These wires are located in a two pin gray connector by the front of the drivers side fuse box.
*3 In a green 24 pin connector.
*4 Yellow on the EX and lt.green on the LX.
*5 Located in the same plug as teh door lock wires. Also found in a 14 pin green plug at the driver's fuse box on the EX model.
*6 Only available on the EX model
*7 In a green 4 pin connector
*8 Above the hood release in a 18 pin connector. On the DX and LX models, also found in a 2 pin connector behind the driver's fuse box.
*9 Arms and disarms with the door locks on the EX models. The LX models arm only with the factory transmitter.
*10 On the EX the wire is located at the drivers power window switch. On the LX the wire is at the keyless/security unit which is attached to the driver's underdash panel.
*11 The tach test connector is located to the driver's side strut tower on the 6 cylinder motor. The tach test connector is a white 2 pin connector.
*12 Located at the first plug on the ECM, it is a 32 pin gray plug. The ECM plugs can be accessed by pulling up the carpet on the passenger side of the center console. There are 4 plugs total
jac2
Member - Posts: 36
Posted: September 19, 2003 at 7:19 PM / IP Logged
thanks,but i need wires that can control passenger side window from the drivers side.
Moderator - Posts: 12,488
Posted: September 21, 2003 at 9:05 AM / IP Logged
If you look at the information above it tells you the RF window wires for up and down. This is the passenger side window wires.
jac2
Member - Posts: 36
Posted: September 21, 2003 at 7:52 PM / IP Logged
yeah i know,i was asking wire from LF that can control passengers side windowup and down like a master switch!?,not from RF side! also i cannot find same wires for passenger side from LF: blue WHITE/ blue yellow
